Led rgb strip
Post Date: 2019-11-11
Jhamby1980 View Drop Down
  Quote Jhamby1980 Quote  Post ReplyReply bullet Topic: Led rgb strip
    Posted: 11 Nov 2019 at 6:16pm
So the led strip that came with my lumos was not plugged in? Does this go to the motherboard or psu?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 Nov 2019 at 3:19am
Same reply as your other post:
Hmmm, sorry about that. Definitely would plug into the motherboard just like a fan header. See if you find an open receptacle nearby. Be sure you are grounded, and its always a good idea to unplug your system from the wall. After you unplug, press and hold the power on button for several seconds to discharge capacitors on the motherboard. This is all very precautionary, but safe. Good luck.
If you can't figure this out, call DS support and they will walk you through it on the phone.
This page was generated in 3.601074E-02 seconds.
