LED strip not working
Post Date: 2019-08-23
Exotic View Drop Down
  Quote Exotic Quote  Post ReplyReply bullet Topic: LED strip not working
    Posted: 23 Aug 2019 at 7:07am
I bought a pc on digital storm 3 years ago vanquish 5. It worked fine for 3 months then I changed the color mode and it hasn’t worked since. When I turn my pc on it flashes for a second then nothing. I replaced the power cable for the sensor because it looked like the pin was exposed and not securing right but it did the same thing. Should I just replace the strip or could it be a pc problem.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 24 Aug 2019 at 4:09am
IMHO, the only PC problem would be no power to the strip, but the fact it flashes at you shows that's not the case. Seems to be the LED strip is at fault.
This page was generated in 1.953125E-02 seconds.
