Lian li Pc-p80 VS Corsair 800D
Post Date: 2010-10-05
miguelon54149 View Drop Down
  Quote miguelon54149 Quote  Post ReplyReply bullet Topic: Lian li Pc-p80 VS Corsair 800D
    Posted: 05 Oct 2010 at 2:55pm
Hi guys, as the subject says, I dont know which case to choose, I like the lian li cause the space and the fans keep the air moving within the case, and the 800 D  is all black and cable management is superb, and painting the lian li is 500 usd :S
Any advice will be well received.
Thx in advance
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:04pm
well you didnt really give a lot of info.. what hardware? what kind of cooling?
id leave painting out as the color of something is pretty far away from mattering to performance
AmbientChong11 View Drop Down
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:06pm
Lian li and the Corsair 800D are both good cases. I prefer the Corsair b/c it has the side panel display. The dimensions between the two are not much different.
For $500, I would invest it into something else like liquid cooling, GPU, or a monitor, but it's your preference.
Dragoonseal View Drop Down
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:10pm
The HAF 932 has much better air flow than the Hailstorm (Corsair 800D), has just about as much space, and is $276 (!!) cheaper.
Ditto and ditto compared to the Lian Li, and is $334 (!!!) cheaper.
Please, spend your money wisely, and simply avoid both of those.
Lilim
Intel Core i7 920 @4.2GHz
  Quote miguelon54149 Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:30pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:33pm
yikes
the lian can come close to supporting that cooling without heavly modding it
even the hailstorm will have one of those radiators hanging off the back of it
id suggest you have a look over the buying guide in my signature
  Quote Dragoonseal Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:39pm
Bah, I'm gonna have to bow out of this thread, those kinds of configs will give me an aneurysm.
Just.. at the very least do yourself a favor and don't select those terrible old Nova SSDs. Select a Corsair Force or Intel SSD instead, either of which have like 10 times better small file performance and similar or better GB/$ prices.
Lilim
  Quote miguelon54149 Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:43pm
ok, change the ssd, and the guido doesn´t open, can you send it to me via mail pls???
  Quote miguelon54149 Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:47pm
man, can you do me a favor? (seriously) build a config with 8k of budget, so i can see how can I spend my money wisely.
Thx in advance
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 05 Oct 2010 at 3:51pm
what browser are you using, heres the direct link
you can also find it at the top of the configuration section in the forum
