Light up fans
Post Date: 2019-06-19
BlazinXo View Drop Down
  Quote BlazinXo Quote  Post ReplyReply bullet Topic: Light up fans
    Posted: 19 Jun 2019 at 8:47am
Hi, I have 2 questions. I currently have a vanquish 7 level 4. I would like to install 2 corsair blue light fans to the top of the tower in the mount locations. My first question is will I be able to do that with no issues? And if so where would I plug those 2 fans into the motherboard? Any help is very appreciated, thank you!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Jun 2019 at 7:50am
Shouldn't be very difficult at all. Check out where the other fans are plugged in and go there. You might need need a splitter cable that plugs into the mobo and then takes multiple fan plugs from several locations, but I doubt it.
  Quote BlazinXo Quote  Post ReplyReply bullet Posted: 21 Jun 2019 at 8:15pm
Thank you so much for the help! Upon further investigation my PC had a pwm circuit with 6 fan headers, 6 LED headers, 3 RGB headers, and of course the CPU header. So installing more fans was simple. Thank you DS for making things so easy with your builds!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 22 Jun 2019 at 3:56am
