liqued cooling gunk
Post Date: 2013-10-08
cat1560 View Drop Down
  Quote cat1560 Quote  Post ReplyReply bullet Topic: liqued cooling gunk
    Posted: 08 Oct 2013 at 3:30pm
any of you guys own a digital storm desktop with liquid cooling
if so please tell me what mantnience you are doing and if you have any issues like gunk in your loop
thanks David
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 08 Oct 2013 at 9:06pm
I don't own one, but I'll take a shot here for you.  Your basic liquid cooling maintenance is pretty simple.  When your res drops below the 50% mark, refill.  Take it up to about 80% should be good.  That leaves plenty of room for any air.  Never fill all the way.
Unless you have a colored dye, you don't need to worry about gunk.  Algae on the other hand can be an issue, but a simple kill coil or a biocide will take care of that.  Should you feel the need, about once a year, drain your loop and refill it with free liquid.  You can contact DS to find out what brand they use if you'd like, or use one of your own.  Just be sure to do a nice clean flush, and refill.
Simple and easy.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 08 Oct 2013 at 9:57pm
I know DS currently uses XSPC EC6 coolant.
  Quote cat1560 Quote  Post ReplyReply bullet Posted: 09 Oct 2013 at 9:12am
after talking to them they said they use fluid xp
  Quote cat1560 Quote  Post ReplyReply bullet Posted: 09 Oct 2013 at 12:37pm
also any of you guys have any issues with plasticizer gunk in your loop
  Quote cat1560 Quote  Post ReplyReply bullet Posted: 14 Oct 2013 at 3:13pm
any one here to share their experience
kernols View Drop Down
  Quote kernols Quote  Post ReplyReply bullet Posted: 21 Oct 2013 at 7:19pm
I have a custom loop for my cpu and i threw a silver coil inside mine when i received the computer. Liquid is still crystal clear after a little over a year
Edited by kernols - 21 Oct 2013 at 7:19pm
