Liquid Cooling Options Question
Post Date: 2009-05-25
dtrader View Drop Down
  Quote dtrader Quote  Post ReplyReply bullet Topic: Liquid Cooling Options Question
    Posted: 25 May 2009 at 10:20pm
Hi All,
Can any of u tell me what the difference is between the following Liquid Cooling (LC) systems:
  1. H2O: Stage 3: High-Performance Liquid Chilled FrostBite System
  2. H2O: Stage 3: Specialized FrostBite Seperate Dual Loop System
How does each work?  What performance gains, if any, does one have over the other?Cry
Thanks in advance for your help!!!
-DTrader.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 May 2009 at 10:48pm
dual loop is when basically you get 2 LC systems, one is for the CPU and then the GPU get their own, so with a dual loop, you got 2 pumps, reservoirs, radiators.
since the GPU gets pretty hot, if one ever wants to have the LC on GPU also, its best to give the GPU its own line so its heat does not make things warmer for the CPU.
hope that helps.
it you sitll have questions please ask
