Liquid cooling question
Post Date: 2011-10-20
escopab View Drop Down
  Quote escopab Quote  Post ReplyReply bullet Topic: Liquid cooling question
    Posted: 20 Oct 2011 at 7:18pm
Good afternoon everyone.  These first 3 question are directed at the DS staff.
1. When utilizing LC stage 6 (1 3ple rad for grafx cards & 1 2ble rad for cpu) on the HAFX case do you mount the rads inside or outside of the case?
2. Also, if mounted inside to the top of the case do you keep the 2 200mm fans or are they eliminated?
3. What is the default configuration for mounting the rads and what is the most optimum?
These questions are directed at DST4ME.
I will be building my x79 comp as soon as the platform becomes available here on DS.
It will most definitely be a tri sli setup since I will be running 1 ~ 2 (1920x1080) 3d projectors  at once and a 30" 2560x1600 monitor at some point.
1. Not knowing the load temps of the SBE cpu would all 3ple rads be way more efficient at dissipating  heat than a 2ble and a 3ple?
2. Can the HAF case handle cooling 3 cards and an OC cpu efficiently without LC?  I only ask since LC is considered a luxury.  If I don't need it I will not waste the money.
Thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Oct 2011 at 8:18pm
OK for my questions:
1. no matter what, triple rad will always do better then double assuming they are both quality or same model just different size, otherwise the make/model of the rad has a lot to do with it, a good double rad will out due an average triple rad any day. So yes size does matter but quality/performance first.
2. I would not recommend the haf x for full lc, you are not going to get the best lc performance out of it, and its not the best/sturdiest choice for full lc setup, for full lc you gonna want my case which is the corsair 800d (hailstorm). with that as you see in my sig, I have triple on top, and triple outside back.
not knowing sbe temps its hard to say if you want lc or not on that platform, if its anything like p67 you won't, cause with oc temp is not just an issue, vcore is also an issue.
now for DS staff questions, tho I'm clearly not staff, I think I can answer a few questions.
1. they maybe able to put the triple on top and the double on bottom, personally I don't care for that kind of a setup, its ok, but its not optimal.
2. I believe you will lose them, but I'm not 100% sure, keep in mind in comes with one fan on top, you have to add the second one.
3. default is on top or exhust from what I have seen here, top would be more optimal, outside being the best, this is why:
if on top, then either you are sucking hot air from the case thru the fan/rad, making your temps tad bit higher, or you gonna try and do the unthinkable and push air down in the case from top, this will make this rad's temps better but now you are pushing all the hot rising air from the case back into the case and you are using the hot air from the rad to do it.
outside sucks/pushes fresh air thru rad giving you optimal temps.
now having said all that, my cpu rad is a triple, and its inside top, its temps are under very very heavy load in the 60s range. So would my cpu temps be better if I put the rad outside? yes, Do I need it? heck no, 60s load temps will let my cpu out live the pc itself, now my vcore is a whole different story
hope that helps a bit, at the end, if you are going air cooled go haf x, if you are going full lc go hailstorm, and forget the rest.
  Quote escopab Quote  Post ReplyReply bullet Posted: 20 Oct 2011 at 9:02pm
Man you're quick!  Thanks for the hasty reply.
1. So no HAFX for full LC.  What does the 800d offer that HAF does not for full LC?  I have been following your posts for some time now and you usually favor the HAF for air cooling.  I thought it would work well for both LC and air alike.
2. Yes...your rig is a total beast and probably will scare little kids come this halloween.Evil
Is it loud?  If not what did you do to make it quiet (fans & rads)?  I asume those rads are special order.  I viewed the component list on your pics page but I can't tell what is what Im%20with%20Stupidyeah...  I am still learning.
I will save whatever info you provide me and utilize it when I go to place my order.
sneaky George W View Drop Down
  Quote sneaky George W Quote  Post ReplyReply bullet Posted: 20 Oct 2011 at 9:44pm
escopab,
im not DST4ME nor DS staff... but i have a HAF X and have tried liquid cooling things in it. I would say that the HAF X is designed for High Air Flow, not LC. that said, a tripple fits on the top, but you have no where to put the double. ive never used or seen a 800d in person, but i think it would be better. dont get me wrong, the HAF X is great, and i bet that DSO could LC everything in it, but it would be sub optimal, and a lot of work. (btw, i would love to see them do it... i think such a system would be beautiful...)
  Quote escopab Quote  Post ReplyReply bullet Posted: 20 Oct 2011 at 10:09pm
Thank you GW.  You have had first hand experience trying to LC the HAF case and it apparently wasn't optimal.  I was hoping for the best of both worlds.  A high air flow LC config that would keep all components not under LC nice and cool (ie. motherboard and ram).  I am revising my config to now include the 800d or the Lian Li case.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Oct 2011 at 10:20pm
The 800d is a much more sturdier case which is what you need with full lc setup.
yes the rads and fans are custom, if you want quiet you have to go custom.
for air cooling I always recommend the haf but for full lc I recommend the 800d.
I pointed out my rig so you can see how two triple rads would work with 800d, one inside top and one outside back as you see.
Edited by DST4ME - 20 Oct 2011 at 10:20pm
  Quote escopab Quote  Post ReplyReply bullet Posted: 21 Oct 2011 at 1:41pm
DST thanks again.  I will be bugging you for the make and model of those custom fans and rads when I am ready to build.  One last queston.  What do you think of the Lian Li case for full LC?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Oct 2011 at 4:39pm
Lian Li cases are great, if you want lot of room check out Mountain Mods, but I can tell you first had the 800d is a beast and great for the lc setup, plus the hotswap bays that support both 3.5" and 2.5" drives and etc.
fan are Scythe gentle typhoon and the rads should be xspc "rx" series rads.
Edited by DST4ME - 21 Oct 2011 at 4:40pm
This page was generated in 5.200195E-02 seconds.
