Liquid Cooling question?
Post Date: 2019-07-17
Cdawayiam View Drop Down
  Quote Cdawayiam Quote  Post ReplyReply bullet Topic: Liquid Cooling question?
    Posted: 17 Jul 2019 at 10:38pm
As some of you may have seen i have been on an upgrading spree! I was thinking about liquid cooling my CPU. Does anyone have any suggestions for some good liquid cooler's? and also ones that will i will be able to use with the vanquish 7? Thanks in advance!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 18 Jul 2019 at 12:32am
Hi,
The Corsairs found here are all very good. NZXT's Kraken has very good reviews also.
Figure out where you will install it in the system so that you know if you can fit a single, double or triple fan set up. Good luck.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 18 Jul 2019 at 3:53am
Yep...+1
  Quote Cdawayiam Quote  Post ReplyReply bullet Posted: 18 Jul 2019 at 7:29am
Horserator i do not see a link in your message are you able to re link it?
