Liquid Cooling Question
Post Date: 2009-10-13
noob101 View Drop Down
  Quote noob101 Quote  Post ReplyReply bullet Topic: Liquid Cooling Question
    Posted: 13 Oct 2009 at 12:53am
Is liquid cooling maintenance a hassle,when should i clean the parts and when to change the coolent.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 8:28am
not a hassle at all, you just check fluid level once a month and add some if its needed (2 minutes of work).
once every 3 years you wanna flush it.
  Quote noob101 Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 6:40pm
Oh i thought it would be a hassle.Lc is best for ocing right? Thanks btw
  Quote noob101 Quote  Post ReplyReply bullet Posted: 13 Oct 2009 at 6:44pm
I just want to know all the up's and down's on lc because i'll be purchasing a DS computer when the gtx 300 series is out.CAN'T WAIT! :)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 5:48am
LC is for best load temps, it helps alot with temps if you are ocing.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 8:32am
100% necessary for better temps, but not necessary for oc.
Edited by DST4ME - 14 Oct 2009 at 8:32am
NoDs212 View Drop Down
  Quote NoDs212 Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 9:22am
Here's a question, is it safe to OC a 920 2.66ghz all the way up to 4.0 or is that adding too much stress?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 9:37am
its fine but you should do it with frostbite LC
  Quote NoDs212 Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 9:43am
sweetness Ermm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 9:56am
4.0 is around the max safe on air, it depends on the chip, 4.2-4.3 with really good chips, using  good air cooling. I have seen  4.5Ghz on air, with decent temps, but it was very loud, dual 3000 RPMM fans on the heatsink.. lol
  Quote NoDs212 Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 10:03am
haha did it sound like a generator?!?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 10:51am
Ya I have seen 4.5 on air also but if you try that with your DS system, its bye bye warranty, cause that will void your warranty, DS oced to 4.0 or higher only with frostbite, so I assume that if you push to that point with air, it will void your warranty.
  Quote NoDs212 Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 11:01am
hell, if i went to 4.0 i'd want it to be safe reguardless, warranty or not
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 11:27am
rasing the OC will void the waranty? I did not know that.  mine came OCed @ 2.8Ghz and now runs 4.2Ghz  lol with better temps and lower V core.. Smile
  Quote NoDs212 Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 11:36am
Impressive, Done yourself or by DS?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 11:38am
DS dids the build an the original OC, then I took over. lol
Davis View Drop Down
  Quote Davis Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 1:24pm
Your original came OC'ed at 2.8??? stock is 2.66 Thats not much of an oc..Was there something wrong?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 2:06pm
mine was not an i7.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 2:50pm
justin why do you alway edit what I say, and then respond to the edit? I didn't say raising your oc will void warranty, I clearly said if you raise your oc past 4.0GHz on air it would probably void your warranty as DS does not support 4.0GHz oc on air themselves.
Edited by DST4ME - 14 Oct 2009 at 2:51pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 3:01pm
i have never edited what you say??? I quoted you... no editing, it clearly is quoted, word for word..... forget your meds today??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 3:08pm
how can you say you quoted me word for word when your response clearly left out the part about air?
to say you will lose your warranty if you oc above 4.0Ghz on air is not the same as saying
I didn't say raising your oc will void the warranty, I said raising your oc pass 4.0Ghz on air could void your warranty.
Edited by DST4ME - 14 Oct 2009 at 3:10pm
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 3:10pm
because the quote says air? lol  Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 3:13pm
but your response doesn't say air, it just says raising oc, which is not what I said
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 3:20pm
I did not think I needed to, hence why I quoted you to explain it...
So do you think my warranty is voided??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 3:36pm
not sure, if you are on air, it might be, I have never seen anybody do what you did, so it hard to tell, they might make an exception since you know what you are doing, I'm just thinking since they don't support 4.0 or higher on air themselves they may not support the user doing it, I could be wrong.
  Quote noob101 Quote  Post ReplyReply bullet Posted: 14 Oct 2009 at 7:17pm
Cool at first i was gonna go with intel core i7 975 then i looked in the DS forums everyone says it's a waste of money.I'll be going with the intel core i7 920 and ocing to stage 2,does it make a huge difference then stage 1?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Oct 2009 at 10:37am
in gaming it will not, I think you best is to stay with stage 1 oc.
  Quote noob101 Quote  Post ReplyReply bullet Posted: 15 Oct 2009 at 8:16pm
Thanks for the info :)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 16 Oct 2009 at 11:22am
My pleasure
This page was generated in 0.1289063 seconds.
