Liquid Cooling Question
Post Date: 2009-11-07
Zero223 View Drop Down
  Quote Zero223 Quote  Post ReplyReply bullet Topic: Liquid Cooling Question
    Posted: 07 Nov 2009 at 4:56pm
Ok so I've decided to buy this computer from DS.
http://www.digitalstormonline.com/comploadsaved.asp?id=341241
The overall parts to the computer are basically the same. (No upgrades) Im wondering how the liquid cooling system for this computer will work. It says that it comes with the H2): Stage 1: Asetek Liquid CPU Coooler (240mm Radiator)(High Performance Edition). About how many times will I have to change the liquid/coolant? (Ex: Every XX Months) When I order this from DS will it come with a free bottle of coolant with it or something or will I have to go and order one with it and if so where is a good place? Does the kind of coolant matter? Ive heard some bad things on liquid cooling as well, such as that if even a single drop gets on a part of the computer it basically fries the whole system. Does this also apply to the non-conductive ones as well? Please tell me any other things about liquid cooling that you think will help me, thanks. (As you can tell Im really new to the whole liquid cooling)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 5:23pm
sounds like whoever talked to you about LC had no idea what they were talking about, it can spill and nothing will happen cause it is non conductive fluid, I don't know anybody that uses a conductive fluid, simply cause that would be stupid.
asetek is not a real LC system and it does not provide the performance of a real LC system, frostbite is a real lc system. asetek does not work the same way either, in short you don't need to add fluids and such to asetek, if I were you I would either go with frostbite or Noctua NH-U12P.
your build has got lot of things you don't need and are waste.
What resolution will you be gaming at?
Edited by DST4ME - 07 Nov 2009 at 5:23pm
  Quote Zero223 Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 5:27pm
The things that I didn't really know about I left alone because I didn't want to mess with. (Can you tell me how to private message so i can talk to you on there? I couldnt find out how.)
Edited by Zero223 - 07 Nov 2009 at 5:28pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 5:40pm
they don't pm here, if you can tell me what resolution your monitor is gonna be running I can help you.
  Quote Zero223 Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 5:43pm
Well the monitors im getting are running at 1920x1080. I will be dual screening if and maybe triple if my parents are willing. (I want a set up that will last me for a LONG time)(Oh btw if you dont mind do you have something like Aim or msn that i can use to talk to you because its faster? I need to know this info by tonight apprently XD)
Edited by Zero223 - 07 Nov 2009 at 5:44pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 6:02pm
Sorry boss I don't msn or things like that.
this is better:
Here you go Ticket# 351280 --- Price: $2197 (To see this build click here) Price after current promotion $2197
Interior Finish: - Not Available
Trim Accents: - Not Available
Card Reader: - Not Available
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Liquid Color:- Not Available
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Tweak Windows: - Not Available
Office: - Not Available
Benchmarking: - Not Available
LCD Display: - No Thanks
or
Ati system:
Here you go Ticket# 351281 --- Price: $2213 (To see this build click here) Price after current promotion $2213
if you need extra gpu power you can always add another card later and spend less.
  Quote Zero223 Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 6:06pm
Ok so no liquid cooling is neccessary right? What is the biggest difference in performance between liquid cooling and the air cooling?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2009 at 6:07pm
temps under load, LC always gives the best temps under load, but I'm talking about frostbite here and not asetek.
Optimystic View Drop Down
  Quote Optimystic Quote  Post ReplyReply bullet Posted: 11 Nov 2009 at 4:35pm
Just got my system today and already have a question about the liquid cooling. When I first started the system, it gurgled a little and sounded like someone peeing LOL. That only lasted a couple of seconds then it was silent. Later on it made that sound again for a couple of seconds, and has been silent ever since. Since I have never had a LC system before, I was wondering if this is normal? I am trying to tell if the red liquid is moving through the tubes but can't really tell. The top of the fluid in the reservoir keeps waving around like it's moving, so it would seem all is well.
I'll post a review later tonight when I've had more time to mess with it.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2009 at 4:36pm
if the liquid didn't move your temps would shoot up and things would get hot.
  Quote Optimystic Quote  Post ReplyReply bullet Posted: 11 Nov 2009 at 4:38pm
what about the "trickling water" noise? Is that normal occasionally?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2009 at 4:45pm
yes that is fine
  Quote Optimystic Quote  Post ReplyReply bullet Posted: 11 Nov 2009 at 4:48pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Nov 2009 at 5:07pm
My pleasure
Psimon View Drop Down
  Quote Psimon Quote  Post ReplyReply bullet Posted: 12 Nov 2009 at 9:14am
You can get flow meters and install them in-line if you're the enterprising sort, but the easiest way to make sure your LC system is operational is as DST4ME said, monitoring your temps.
For the CPU I really like Realtemp. It doesn't have a windows startup option but that's easy done by just placing it in the Startup folder. I glance at it every now and then. It also keeps track of the maximum and minimum temps from the moment it's booted, and I like to check out how my latest game heated up the CPU and GPU's (using Precision for the latter).
There's other good utilities like HWMonitor and CPU-Z also. Some like Everest, and I've heard good things about it, but you have to pay for that one.
CM HAF 932*EVGA X58 3X SLI* i7920 4.0Ghz OC*6GB Mushkin RAM*EVGA Titan Sprclked*Samsung 850 Pro 1TB*Logitech Z5500*Razer Death Adder*Corsair 1000HX PSU*LG 34UM95 Monitor*Windows7Ult64
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 12 Nov 2009 at 12:59pm
the trickling noise is air working out of the system, should not make a peep once it is bled out.
  Quote Optimystic Quote  Post ReplyReply bullet Posted: 12 Nov 2009 at 9:44pm
Thanks for the recommendations on the software, I was interested in getting a temp monitoring program but didn't know what to use. Now I do!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Nov 2009 at 12:56am
use realtemp and HWMonitor
