Liquid Cooling
Post Date: 2009-04-22
Kitijima View Drop Down
  Quote Kitijima Quote  Post ReplyReply bullet Topic: Liquid Cooling
    Posted: 22 Apr 2009 at 3:13pm
If I choose not to go LC, would the HAF932 case be overkill? I mean size etc... I have been told not to go LC now because there are so much problems of leakage. I haven't read once on this board anyone experiencing any leakage. I am just wondering if I am getting the right advice. He did say go with the V8 Coolermaster.
One of my favourite hobbies is I like to procrastinate...O_o
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Apr 2009 at 3:18pm
You are getting bad advice, LC on the CPU is a great idea, one of many reason we love HAF is because its great with air or LC.
The LC systems are air tight and you can spin the PC any way you want.
also the liquid is none conductive, which means if some who the tubs got cut and the liquid spilled, there will be no damage.
the V8 is great also but LC is always better, if you have room in your budget go for it
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 23 Apr 2009 at 2:22am
thats not true lol ;)
non conductive liquid isnt completely non conductiive
you can still fry your stuff when it spills, there is just less chance that it will happen
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Apr 2009 at 4:34am
you can also get hit by lightning, your chances are better with the lightning.
we have had members here that have had spills and nothing happened the liquid itself will not do anything so spilling it will do nothing and is harmless, non conductive means non conductive, its the condensation that might hurt the system but that is if the spill liquid is left in the case.
Edited by DST4ME - 23 Apr 2009 at 4:36am
  Quote Kitijima Quote  Post ReplyReply bullet Posted: 27 Apr 2009 at 1:09am
As always thanks for your input DST4ME, what would DS do without you?...
Off topic here but what do you think of Zalman's CNPS9900 LED? I read the review on MPC and they love it.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Apr 2009 at 1:27am
Don't know much about it but I doubt if it will be too much of a differ from the v8
