liquid cooling vs air
Post Date: 2019-08-01
*Thomas* View Drop Down
  Quote *Thomas* Quote  Post ReplyReply bullet Topic: liquid cooling vs air
    Posted: 01 Aug 2019 at 9:22pm
Hello, i'm currently looking in to my next system and wanted to get everyone's opinion on liquid cooling vs air.. do you guys think its worth the extra money? All opinions welcomed!
p.s not talking about closed loops just the hydrolux system.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 1:24am
Personally, no disrespect to The Smart Guys® that hang around here, I will never liquid cool any computer. I don't need overclocking, I don't do "min/max", and I'm not interested in squeezing every little ounce of performance out of a machine like this. People who designed these things are much, much smarter than me and so I'm going to run it within its original parameters. (Side note, no "aftermarket" products on my cars, either.)
I spent many years in the plumbing trade and have seen the corrosive effects of liquids getting into places where they shouldn't be.
But then again, that's just my personal 2¢ on the matter.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 1:58am
You can get a real good system all on air and never have thermal issues and one lc and have all sorts of issues starting with leaks. If you are going to tinker with the cpu variables you might want to keep it liquid cooled otherwise......the AIO coolers are about as trouble free as air nowadays.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 2:02am
With all due respect to Air Snaike...lol...fear is the mind-killer!
When you buy an Intel K or X Series processor for your build, you ARE already paying for a processor DESIGNED BY INTEL TO BE OVERCLOCKED.
Unless you Overclock those excellent K & X Series CPU's, you are not unlocking the full performance they were designed by Intel to produce.   Liquid cooling is the way to get that performance and keep temps safe & chilly, and the better the cooling you can invest in...the better and more stable your Overclocks will be.   DS HydroLux Pro liquid coolers are excellent and dependable.
DS has a decade of solid experience building Overclocked liquid cooled systems... so my advice would be... if you are interested in liquid cooling and Overclocking...then choose HydroLux Pro cooling for the best performance and go for it!
DS will make sure it's done right.
Edited by HockeyBuck - 02 Aug 2019 at 2:03am
  Quote Snaike Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 3:54am
HockeyBuck... that's why they make Chocolate AND Vanilla.
Edited by Snaike - 02 Aug 2019 at 3:54am
ThePinkGoat View Drop Down
  Quote ThePinkGoat Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 7:09am
A standard AIO Corsair cooler is plenty. Hydrolux is only for extra show, it provides no additional measurable value that any of you can actually measure and say, "I see the difference."
Hydrolux can have leaks, the pump can have issues and so on. You have to WANT to deal with it or it's going to cause issues. If you're not willing to change your oil in your own car then you will probably not want to manage Hydrolux.
And I'm not saying Hydrolux is bad at all. It's fantastic, it looks the best and cost the most.
My 2 cents on Liquid cooling.
My ODE Level 3 2600k i7 has a Single corsair AIO. I'm pretty sure it has no more liquid inside after 8 years of owning it. And my CPU is overclocked to 4.5 never had an issue with it.
GrandesBollas View Drop Down
  Quote GrandesBollas Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 8:16am
I think the type of cooling selected is really going to depend on your intended usage: run at stock, run overclocked, run all cores maxed out for long periods of time.
While researching the subject, I found the following Velox review:
https://www.youtube.com/watch?v=9ZcosjCV9DU
The installed AIO becomes noticeably loud during heavy workloads. It keeps up with the demand, but the noise level may be something for you to consider.
Dondomingo View Drop Down
  Quote Dondomingo Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 8:30am
Hockeybuck is correct. Intel does know their processors are easily and safely capable of speeds beyond what they ship at. However because of the number of variables, I.e everyone has a different setup at home, so they choose to ship at a lower speed instead of risking thousands of RMAs a day because of enduser mistakes.
To the OP, Thomas
I’ve been using water cooling for 17 years now, even on my non-clocked PCs. Why? Because of science. Heat destroys everything over time, lowers anything’s lifespan. Water cooling is superior to air cooling by a far enough margin that it begs the question, why isn’t everyone doing it by default.
I wish GPU manufactures would get on board with this so a simple solution for WC video cards could be the norm instead of a money investment. Even with air cooling I’ve burnt out a fair share of vid cards over the years. Alas every mfg makes their version different so it makes it to where only certain GPU’s can be water cooled.
There are plenty of cheap solutions for WC on the market or here at DS, that are also maintenance free. No hassles.
I’d say go for it if your budget has room when building a pc, even if it’s not OC. That’s my two pixels.
Edited to fix iPhone spelling
Edited by Dondomingo - 02 Aug 2019 at 9:38am
  Quote *Thomas* Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 8:54am
Thanks for all the reply's and interesting reads guys Still not sure which i'm gonna go for but i'm gonna look more into it.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 9:45am
With the HydroLux Pro you can get the gpu(s) lc also. It really is the only reason to get it. Otherwise the Corsair AIO's are the best and trouble free.
  Quote ThePinkGoat Quote  Post ReplyReply bullet Posted: 02 Aug 2019 at 11:21am
Corsair 100% - Best warranty, sure it can have issues like any other item on the planet. If you search these forums, you will find very very little if any issues with Corsair AIO. Other LC options have plenty of good/bad feedback.
gdead65 View Drop Down
  Quote gdead65 Quote  Post ReplyReply bullet Posted: 04 Aug 2019 at 11:31am
I differ on the Air vs Water.
I was running a corsair h115 aio for a few years (mild oc on a 7700k)and here is my experience
1. First year- all good
2. Second Year is when things started to get wonky- Excessive air bubbles or blockages beginning (about to tear apart the unit to see what the issue really was)
-Water / CPU Temps were creeping up beyond comfortability over extended usage.
- Tap Pump and jiggle hoses to get temps back to norm for a week or so.
- Rinse wash and repeat
- Constant worry if Pump will fail or temps will go on a runaway streak
-Constant checking on temps during gaming....darn my OCD
as for AIR
Bought a noctua dh15s and:
- temps running cooler than on AIO
- Zero Noise
-Not as sexy looking- but does the job very well
Apollo i7-7700 1070
Ordered: 2-12-17
Stage 1: 2-14-17
Stage 2 & 3: 2-16-17
Stage 4 & 5: 2-21-17
Stage 6: 2-23-17
Stage 7: 2-25-17
  Quote hoserator Quote  Post ReplyReply bullet Posted: 04 Aug 2019 at 2:45pm
If DS still offered that Noctua, we would be recommending it for its efficient cooling ability and total reliability.  Unfortunately, as you know. it is BIG and has a tendency to frown on mishandling, which as it turns out, is the shipper's number one priority (I am being sarcastic) so....no more Noctuas. The images were awful!!
My experience:
-I have a HydroluxPro (cpu and originally 4x980s, now 2x2280Tis) and have learned to do all with plumbing. You must or will you will be suffering a lot. It requires maintenance.
-I have an AIO and have no issues with it at all. Temps are very good.
-Have just built my first ever pc (after learning all about plumbing, why not?) and installed a Noctua DH-15S. Runs cooler than the AIO, And very quiet. Changed the case fans to MLs. Can't hear them.
So there.
I like the fully lc system best. It is a cooling beast.. And I know it intimately so I am not scared of it anymore!
Big%20Smile
PS. I am not knowledgeable about these things, just learned with the  help, guidance and support of some very giving members that used to frequent a lot here and I miss them so much. Sad
Edited by hoserator - 06 Aug 2019 at 2:12am
  Quote oldlady RPGer Quote  Post ReplyReply bullet Posted: 05 Aug 2019 at 2:23pm
I bought my "cube" in 2011 from DS. And I have LQ just on the processor(i7 990X extreme OC to 3.9). Still running strong. I do have experience with Tygon tubing and liquid systems because I'm a ECMO Specialist. So draining and maintaining is all good for me. And I can change the cable zip ties and Tygon if I wanted to. Well I also have 11 fans on my system so I guess Im over cooling?
It all depends on what your comfortable with. I'm more comfortable with the cooling because I deal with lots of tubing and water pumps in my job. I had more issues changing the video card to a Star Wars Titan XP.
And once again I thank all the cool people on this forum for there help!!!!
  Quote Dondomingo Quote  Post ReplyReply bullet Posted: 09 Aug 2019 at 4:15pm
Hey Hoserator , now that you mentioned it, yeah that is the exception, that Noctuas is a BEAST in cooling power. Beats a lot of the water coolers in performance.
Just as it a brick of awesomeness of shiny metal, it’s just freakishly big and heavy and basically hangs on your side mounted mobo like Clint Eastwood asking “Well, do you feel lucky punk?”
I’m just kidding I’m sure there’s ways to make fit and secure. I mean, anybody who loves muscle cars wouldn’t want a big chrome header coming off their mobo. *raises hand*
