Looking for a little help building a gaming pcPost Date: 2012-12-23 |
| Author | |
BShizzleUniBrizzle
Joined: 23 Dec 2012 Online Status: Offline Posts: 52 |
Topic: Looking for a little help building a gaming pcPosted: 23 Dec 2012 at 8:20am |
Hi, my name is Brenden. I've been out of the pc gaming scene for some years now and I'm ready to get back in. I'm looking for some advice on building a strictly gaming pc. I have
a budget of around 5k. I would prefer to spend less but I don't have to if it will get me to where I want to be. I have no previous equipment and would need the
right monitor and peripherals as well. Im looking to build something
that can handle the latest games running the smoothest framerate
possible. I want to put out the highest resolutions possible on 1
monitor. Basically I dont want to struggle playing anymore games on this
new machine for sometime, does this sound possible with my budget? Some questions I have are:
1) Air cooled vs Liquid cooled 2) Single, Dual, or Triple video cards? 2gb, 4gb? 3) Is 16gb of memory plenty for games now a days? 4) What monitors are worth looking into? 60mhz vs 120mhz? 5) Good processor speed? Dual, Quad, Six core...etc? Extreme performance editions? 6) Motherboards and the best one to fit my needs. 7) I'm unfamiliar with raid options, could someone possibly explain? 8) Power supply. What should I look for as far as power goes? 9) Over clocking. Is this feature worth looking in to? Does it effect the lasting life of the video card or processor? 10) I'm unsure what a good resolution to go for would be, suggestions? That's everything off the top of my head for now. If anyone can help nudge me in the right direction I would greatly appreciate it. Any advice on what to build would be awesome! Thanks in advance to anyone who took the time to read this. This will be my first DS build and I'm very excited. |
Posted: 23 Dec 2012 at 8:46am |
Hi again BSHizzle.. Your budget allows alot of ways to go. I'll answer your questions after but here's a config to check out.
Config # 766637 Cost $ 2957 Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core) Motherboard: ASUS SABERTOOTH Z77 (Intel Z77 Chipset) (Features Thermal Armor and Thermal Radar) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1050W Corsair Pro Silver 1050HX (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (180GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 670 2GB (Includes PhysX) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Noctua NH-D14 SE2011 Extreme Performance H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty 1. The HafX case is the best for air cooled systems. Its front 230mm fan, top and side 200mm fans and back 140mm fans provide excellant air flow. Liquid cooling is nice but not really needed. For your budget you could go stage 4 water and above so your call of course. The Vortex cooler, stage2, are sealed units with no maintenance. I still recommend the air cooler for quiet and relaibility but they do take up more room. 2 For max gaming with pretty much all games on a 23" monitor, a sli, 2x gtx670 will be great. 2GB vram is all you need. 3. 8Gb ram is all games need but I put in 16Gb because its cheap and might help with multi-tasking, etc. 4 and 10.. Lots of us use the Dell U2312HM 60Hz monitor, but there are lots of good IPS monitor to pick from. 5 and 6. The Z77 Sabertooth mobo is a great board with a 5 year warranty as opposed to others with 3 year. The four core 3770k chip is all gaming will use. 7. I don't know raid. Others might help with that. 8. The 1050HX psu is a real nice psu. Its a little more than you need, 800W might do it, but its semi-modular and has a great warranty. 9. Overclocking is worth it. Its a cheap way to get a boost in gaming and done right, like DS does, doesn't effect longevity. Just a place to start but this gives you all you need for great gaming with quality parts. I did mention in other post the ODE level 4. Cheaper with the same gaming performance but this build has better case, psu, SSD, etc. See what ya think and good luck. |
Kaleliar
Joined: 24 Feb 2009 Online Status: Offline Posts: 520 |
Posted: 23 Dec 2012 at 8:50am |
1. Air cooled will do you just fine unless you are doing 4.8GHz+ speeds.
2. It depends on the size and number of monitors you want to run. I think anything over 27" solo youll want dual cards. Dont go for the 590 esque cards as they have no gain over 2 single cards in SLI/Crossfire. 3. 16GB is more than enough for games. 4. Im not a monitor expert but I use the Dell U2412M 24" monitor. As for refresh rates just remember that anything past 60Hz isnt totally needed. 5. Quad-cores will play games just fine. the Hexa cores are more for rendering and photo stuff. Games dont really utilize multi-cores well because most of the action is handled by the GPU. DigitalStorm will get you between 4.2-4.5GHz which is plenty for gaming. 6. Asus boards are the best that they use. 7. Depends on the raid. raid-0 is a performance raid but it has risks. You use 2 drives as a single volume but if something happens to 1 drive you lose all the information, its fast though. raid 1 is a redundancy raid. backs everything up onto a second drive incase something happens. 8. Depends on what you end up getting. 1200W will handle three graphics cards just fine. but if you are looking at a bit less the 1050W will do you great and handle two cards. 9. Short answer, Yes it is worth it, you normally gain 20-25% speed with no harm to the CPU as the stock settings dont really push it. for the CPU as long as its not 5.0GHz+ it will normally last longer than you will keep the computer for gaming. for video cards it means excess heat, i dont do it myself but its very easy to do on your own, many people here in the forums know how. 10. Depends on your monitor. 24" is around 1920x1200. as a single monitor for me it works fine. i really dont need more than one to do what i do (LoL, WoW, SC2, D3 ect). you could get a 30" monitor but you would need 2 cards to run it. and it should be like 2560x1600? or so. the gains between two graphics cards and three are minimal. Edited by Kaleliar - 23 Dec 2012 at 9:14am |
Rock: "We're sub-standard DPS. Nerf Paper, Scissors are fine."
Paper: "OMG, WTF, Scissors!" Scissors: "Rock is OP and Paper are QQers. We need PvP buffs." |
Kaleliar
Posted: 23 Dec 2012 at 8:56am |
#766646
Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core) Motherboard: ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 16GB DDR3 1600MHz Corsair Dominator DHX (High-Performance) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 520 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: ASUS Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Model: BC-12B1ST) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (PhysX) (Overclocked EVGA) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards H20 Tube Color:Red Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (UV) (Creates Glowing Effect for H20 Tubes) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty that would be a liquid option that would run things just fine for about $4500 and leave you with money to spend on the monitor/keyboard, mouse ect. Liquid cooling is fairly easy to maintain but is also a luxury. its not needed to keep things running smooth, it just gets rid of heat faster. Edited by Kaleliar - 23 Dec 2012 at 8:58am |
BShizzleUniBrizzle
Posted: 23 Dec 2012 at 9:35am |
Thanks alot for your all your replies. I learn something new everyday. I'm gonna tinker around with a build and post it, maybe get some feedback on it. I was deff overshooting what i thought i needed, in my head.
BShizzleUniBrizzle
Posted: 23 Dec 2012 at 9:55am |
I like this setup. Thank you very much for your help I really appreciate it. Would you consider somthing along these lines good enough for maxing out games on a regular basis? Would I have to worry about graphic intensive games keeping this setup for a couple years?
Posted: 23 Dec 2012 at 10:08am |
That rig will give you all you need for some time. If it was my money, that's the rig I'd put together.
It's pretty much the best or close to it for most parts. Best of luck and keep us updated. You're gonna love a DS rig. |
BShizzleUniBrizzle
Posted: 23 Dec 2012 at 10:27am |
Awesome! Thx again! Im gonna look into this one now |
