Looking for advice on build for RiftPost Date: 2011-04-03 |
| Author | |
stormfin115
Joined: 03 Apr 2011 Online Status: Offline Posts: 5 |
Topic: Looking for advice on build for RiftPosted: 03 Apr 2011 at 12:07pm |
Hey everyone, I am new to building PC's and I am in desparate need to upgrade my 5 year old system. I want a system that will play Rift well with high to max graphics settings. I use a 1280x768 monitor. Please let me know if the build below is optimal per $ spent. I have a max budget of $1500. Thanks!
Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master Elite 430 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5 2300 2.80GHz (Quad Core) Motherboard: ASUS P8P67 (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 4GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 500W Digital Storm Certified Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (1.5TB Seagate Barracuda (7200 RPM) (32MB Cache) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTS 450 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 2: Asetek Liquid CPU Cooler (120mm Radiator) (Great Value) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Green) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz Boost Video Card: FREE: Yes, Overclock the video card(s) as much as possible with complete stability Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Edited by stormfin115 - 03 Apr 2011 at 12:13pm |
Divine
Joined: 06 Oct 2010 Online Status: Offline Posts: 209 |
Posted: 03 Apr 2011 at 12:49pm |
hmm, your graphics selection isn't going to cut it in my opinion...if you look at my signature thats what im using to play. Ive been playing rift for 4 days now and im set to ultra on every setting and in massive battles im dropping to 50fps, while questing around 125fps. You need to at least be in the GTX card catagory if you are looking be high/ultra settings I would say, but could be wrong.
Also that astek cooling is crap, go real liquid or no liquid at all and select the noctua air cooler which is really good and highly suggested by people on here. You have a small budget anyways, and unless your going with a high overclock "which you cant not having a k series processor" then its just going to raise your budget for no real gain in my opinion. Edited by Divine - 03 Apr 2011 at 1:28pm |
Haf-932
Asus Maximus Iv Extreme 2600k Overclocked ~ 4ghz 8gb Corsair Dominator DHX RAM 160gb Intel SSD WD Black 500GB 850 Corsair PSU Msi Twin Frozr Gtx 680 |
Posted: 03 Apr 2011 at 4:37pm |
For 1200 x 1000 that is a a waste of money, you don't need much to run games at that res at all.
I gave you a 560, feel free to drop it to something lower if you like, at your res a 560 is overkill: Here you go Ticket# 514825 --- $1459 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - HAF 922 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 (Intel P67 Chipset) (New & Improved B3 Revision Without SATA 3G Issue) System Memory: 4GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (500GB Western Digital/Seagate/Hitachi/Samsung (16MB Cache) (7200 RPM) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 550 Ti 1GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.5GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty this pc will stay powerful for a bit longer, but if you want to save some performance then drop the cpu to 2500K, you will lose HT but will save you some money, but the 2600K will stay powerful for loner IMO. either ask DS or if not in the budget, add this fan yourself to the side: haf 200mm non led fan Edited by DST4ME - 03 Apr 2011 at 4:39pm |
stormfin115
Posted: 03 Apr 2011 at 5:06pm |
Thanks for the recommendations, I appreciate the help. I have a question about the SLI dual graphics cards option. Is a 2x SLI really twice as powerful as the 1x version of the same card? I noticed that for another $175 I can upgrade to have two of the GTX 550's. Is this worth it or not necessary for my resolution?
Posted: 03 Apr 2011 at 11:26pm |
I appologize, my build is suppose to the have the 560, but the 550 will do at your res, and no sli is not needed at your res, however with a new monitor and 1900 x 1200 res sli can help.
sli is not twice as powerful, but very close to, it also depends on the game really. |
