looking for help, first DS rig! few ?'sPost Date: 2009-01-14 |
Page 123> |
| Author | |
victimeiced
Joined: 14 Jan 2009 Online Status: Offline Posts: 51 |
Topic: looking for help, first DS rig! few ?'sPosted: 14 Jan 2009 at 8:31pm |
Hello all, i've had the same lame computer for about 7-8yrs now, and it's time for an upgrade heh. I've done my research on sites, and decided on digitalstorm for many reasons over the other guys. Well here's the situation... the only game i play is World Of Warcraft, so i don't need any extremely cutting edge stuff, i have no plans to play the very demanding games. Right now, i'm getting 5-15fps depending on where i am, 20 sometimes heh very sad. I'm really looking to get a steady 60fps or so, again only in WoW.
Here is a link to what i've come up with, anything i should replace or add? Thanks a million in advance for any help i can get, this is my first time buying a real pc heh exciting. Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=227466 **Few things i'm not sure about: should i have the cpu overclocked i guess? also, is the razor barracuda sound card any good? or maybe the asus one? having trouble deciding the final things. |
Dsnewb210
Joined: 01 Oct 2008 Online Status: Offline Posts: 972 |
Posted: 14 Jan 2009 at 8:37pm |
What resolution are you gaming at? What is your budget like? |
victimeiced
Posted: 14 Jan 2009 at 8:45pm |
1680x1050 just got a Samsung 22" 20,000contrast ratio monitor
Budget was originally 1k, now it's more like 1,500 |
Posted: 14 Jan 2009 at 8:54pm |
you need two gpus to play with high settings at that resolution, you can always add a gpu
here you go Ticket# 229644 --- Price: $1534 (To see this build click here) Copy of Specifications: Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core 2 Duo E8400 3.00GHz (1333MHz Front Side Bus) (6MB Cache) Motherboard: NVIDIA 780i Core 2 Quad (Chipset: nForce 780i SLI) System Memory: 4GB DDR2 1066MHz OCZ (SLI-Ready Edition) Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition) Card Reader: - No Thanks Hard Drive Set 1: Operating System: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce 9800GT 512MB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: OCZ Vanquisher (Not Compatible With i7 Processors) Liquid Color:- Not Applicable, I do not have a H20: Stage 3 Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: Yes, Overclock the processor as much as possible with complete stability Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) (For Enthusiasts) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty |
victimeiced
Posted: 14 Jan 2009 at 9:11pm |
Thanks so much for the quick help!
A few things... to my understanding WoW doesn't play off of sli mode, so will the one 9800 GT be fine? is there a big difference worth getting the GTX version? Will 4gb ram be good enough with Vista 64bit? And is it worth it to buy Corsair over OCZ or does it not matter so long as i get the 1066Mhz version? I think the only other thing i need to figure out is Sound, using the onboard mobo sound will tax the system and not sound as good right? Is the Razor AC-1 card any good, or the Asus one maybe? the Asus one would be another 200 bucks, but if it's worth it then i might as well do it now. again thanks so much for such quick replies heh! looks like i'll be confident enough to place my order later tonite hopefully ![]() |
Dsnewb210
Posted: 14 Jan 2009 at 10:01pm |
Your correct.. WoW does not utilize SLI, so having one powerful card is the way to go.. I suggest going with a gtx 260 and forget about adding another card if all you play is WoW.
4gigs will be fine for vista 64 bit, id personally go with the corsair mem. (either way)
Honestly the onboard is good enough, I would just go with onboard now and see if it measures up to your standards.
Just remember, If you don't like the onboard you can always buy a soundcard off newegg and install it with ease.
But if you have your heart set on a sound card, i would go with the xonar. Edited by Dsnewb210 - 14 Jan 2009 at 10:04pm |
Posted: 14 Jan 2009 at 10:25pm |
if all you play is wow then you want to upgrade to a more powerfull card.
IMO not worth it to go from gt to gtx, if you thinking about upgrading go with a 260+ or something like that. ocz over corsair won't matter much, and if anything goes wrong they are under warranty, and yes 4GB is more then enough for 64bit and your apps and etc. I think Dsnewb210 presented the sound card stituation very well and as he said, and our sound guru also recommends, if you gonna get a sound card go with xonar |
victimeiced
Posted: 14 Jan 2009 at 10:30pm |
awesome thanks so much for the help guys. thought of another question... since it's just a single card and i'm not concerned w/ sli, should i stick with the 650i instead of the 780i?
Posted: 14 Jan 2009 at 10:38pm |
no go with 780i, its capable of being upgraded to be pretty powerfull down the road when a q9650 is affordable for you, you can run it with a 780i but not a 680i
Dsnewb210
Posted: 14 Jan 2009 at 11:11pm |
I remember the 780i being a very great/stable board, Good Choice!
Max Storm
Joined: 04 Jan 2009 Online Status: Offline Posts: 12 |
Posted: 15 Jan 2009 at 2:19pm |
Hi,
Could anyone expound a little on the difference between 780i and i7 920? Why get one versus the other other? Obviously price, but what actual performance could one see or benefit from?
Thanks
Posted: 15 Jan 2009 at 3:56pm |
sure,
780i is a mother board that runs core 2 duo or core 2 quad processor chips. core i7 920 is a processor chip. in short you are comparing a motherboard (780i) to a CPU chip (i7 920). Edited by DST4ME - 15 Jan 2009 at 3:57pm |
victimeiced
Posted: 11 Feb 2009 at 6:15pm |
My tax return is already here, so i can finally get this new setup built!!!
Thanks to everyone who helped me on the way! One last thing i want to make sure of, if i ever decided to go to an sli setup, it looks like everything will be pretty much set up for it? Again, atm all i play is WoW so i'm skipping out on dual graphic cards until it's even supported in the game. thanks again |
<8) slunK parade
Joined: 20 Jan 2009 Online Status: Offline Posts: 798 |
Posted: 11 Feb 2009 at 6:22pm |
yea your psu is probly big enough to run a second 9800
Onkel_Ken
Joined: 17 Dec 2008 Online Status: Offline Posts: 2961 |
Posted: 11 Feb 2009 at 6:56pm |
Once again you guys on the forum have helped another person get their dream machine at an affordable price!!
victimeiced
Posted: 12 Feb 2009 at 3:08pm |
i love the forums here... so much to read and learn. but now i'm reading some things that may have turned me off from getting the system up a few posts... been reading this thread:
http://www.digitalstormonline.com/forums/forum_posts.asp?TID=5570 ...and it looks like i'm in the same boat as that guy. hmm, debating now if i should ditch the dual core and go with an i7 system... bahh decisions decisions heh, but it's better if i think everything out now. |
Posted: 12 Feb 2009 at 3:48pm |
he ordered his system already and went with i7 and so should you
Samael
Joined: 26 Nov 2008 Online Status: Offline Posts: 488 |
Posted: 12 Feb 2009 at 4:51pm |
The i7 will just last you longer than the core 2 duo.
Why do they blame me for all their little failings? They use my name as if I spent my entire day sitting on their shoulders, forcing them to commit acts they would otherwise find repulsive - Lucifer
Onkel_Ken
Posted: 12 Feb 2009 at 7:12pm |
The i7 is the hottest CPU out there. Here is a technical review on i7 stuff.
victimeiced
Posted: 22 Feb 2009 at 4:07pm |
I've decided to definitely go with an i7 setup! And the most exciting part for me, is that i'm really going to place the order today! But here is what i'm wondering... something like this looks good, it's what DST4ME recommended to someone else:
here you go Ticket# 243494 --- Price: $1998 (To see this build click here) Copy of Specifications: Chassis Model: Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Interior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 3X SLI (Intel X58 Chipset) (Supports Triple SLI or CrossFire) System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance) Power Supply: 750W Corsair TX (Dual SLI Compatible) (Silent Edition) Card Reader: - No Thanks Hard Drive Set 1: Operating System: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 260 896MB (216 Cores) (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Cooler Master V8 (Compatible With i7 Processors) Liquid Color:- Not Applicable, I do not have a H20: Stage 3 Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - No Thanks Chassis Mods: - No Thanks Boost Processor: Yes, Overclock the processor as much as possible with complete stability Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Tweak Windows: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition) (For Enthusiasts) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty BUT BUT BUT, how much better would the pre-built option be on the ds homepage? It'd be an extra $800 bucks, but some pretty serious upgrades, or so it looks to me lol. http://www.digitalstormonline.com/comploadsavedsd.asp?id=248473 I wonder why they wouldn't put the 1000W power supply in that setup? Will the 750W be fine? Is the prebuilt one worth the extra money? |
Posted: 22 Feb 2009 at 4:24pm |
the special you are pointing to is $800 more, then this build, for $2700 I think we can config a better system then the special
the 1000w PSU allows you to upgrade to future GPUs, so it is very important. you can just add a 1000w to my build, and have it be future proof. but if you don't think you will ever need more then 2 x 260+ then don't worry about the PSU. |
victimeiced
Posted: 22 Feb 2009 at 4:51pm |
cool thanks, yea i'd like to keep the price more in the 2k range, but when i saw that premade deal i didn't know how good of a steal it was, if at all lol.
The most stress the computer will be under would be a game playing, itunes or winamp in the background, and webpages if i were in windowed mode... is 3g of ram good enough for that? Or do you think i'm going to wish i had 6g, and maybe i should just get it now? i'm trying to think of my final questions heh bare with me and thank you for the responses |
Kryhavoc
Joined: 26 Dec 2008 Online Status: Offline Posts: 362 |
Posted: 22 Feb 2009 at 4:55pm |
If 6GB ram would break your budget now, I would suggest get 3GB now and upgrade to 6GB when you can afford to make the change. What you should be trying to get now is what you can afford with best option to upgrade various components as you can afford them.
In most cases, unless you are playing a graphics intensive game or doing something else with high graphics like video editing, 3GB would be good to start with, and upgrade later.
Posted: 22 Feb 2009 at 5:01pm |
if change my config to 6GB of ram the price will go to $2217.0 then you get $125 off that price for the final price of $2092
for multitasking 6GB would be better but here is the deal, as Kryhavoc says, you can always add 3 more GB of ram later. so since you are on a budget, why not go with 3GB now, then if you see its not enough, you can order 3 more GB and if you need help adding them you can ask us or call DS. I don't know if you have ever added ram or not,but is very simple, simple as in a 12 year old can do it, that goes for most of the stuff, adding HDD, adding GPU, adding ram, all of these are extremely simple
victimeiced
Posted: 22 Feb 2009 at 6:56pm |
Here's what the config would look like if i went for the 1000W power supply and 6g of ram...
Ticket Number: 250941 |
Posted: 22 Feb 2009 at 8:05pm |
OK but you have to take these into consideration:
its not $400 more, you forget that you get another $125 off the $2,392.00 with the current promotion, which does not apply to the special. so its $500+ more. second you can change anything in the rebuild and I can assure you that you don't want a 1TB HDD for your OS drive
with a 750w PSU your system isn't really future proof. you have 6GB of ram, you will never notice the difference between 1333 and 1600 and the 920 and 940 are made to run with the 1333. |
victimeiced
Posted: 23 Feb 2009 at 2:56pm |
look good? Comes out to $2253 after rebate. Way over my original plannings, but like most who say we're on a budget... we really just don't want to spend the money LOL But i'm glad i got all the help i did and waited... or i would have been stuck w/ my original core2 duo and other crap that i could never upgrade with. For the extra money now, i won't have to upgrade a single thing for a long time heh. I'm about to order, so this is the last chance to chime in w/ any changes i should make heh
Posted: 23 Feb 2009 at 3:06pm |
everything looks great, nice beast, now you can just add gpus or what ever else you want to this pc and keep it upto date.
only thing you need to change here is your dvd drive, you have chosen the reader, instead choose the writer/reader, it needs to be this one: Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) |
victimeiced
Posted: 23 Feb 2009 at 3:14pm |
ahh thank you, i knew i'd miss something silly heh
Posted: 23 Feb 2009 at 3:16pm |
My pleasure, good luck
lgm25c
Joined: 06 Feb 2009 Online Status: Offline Posts: 77 |
Posted: 23 Feb 2009 at 4:32pm |
DST4ME has ya covered! *thumbs up*
Yeah, for some reason the default in the configuration is reader/reader...
You have a great system. The PSU and 6 GB RAM will keep you happy and give you room to grow for a long time.
The 260 will let you cruise thru WoW, and it's an easy upgrade to add another for SLI for the future - other games, etc. Edited by lgm25c - 23 Feb 2009 at 4:36pm |
victimeiced
Posted: 23 Feb 2009 at 5:57pm |
so, what has two thumbs and just ordered the system above?
THIS GUY hahaThanks a ton to everyone who helped again, especially DST4ME you really go out of your way to make sure people are doing the right thing with their money, i'm glad you changed my mind from my original plannings heh. I'll keep this post updated along the way as i receive word from DS. |
Posted: 23 Feb 2009 at 6:11pm |
My pleasure and you are very welcome, don't forget to post the pic and specs when you get them
victimeiced
Posted: 24 Feb 2009 at 5:36pm |
Stage 1 - Complete 2/23 7:11pm
Stage 2 - waiting i guess i'll try to make room for this thing in the downtime heh |
Posted: 24 Feb 2009 at 5:37pm |
Let the torture begin
Page 123> |
