Looking for Help with a BuildPost Date: 2010-03-05 |
elepheagle
Newbie Joined: 05 Mar 2010 Online Status: Offline Posts: 7 |
Topic: Looking for Help with a Build Posted: 05 Mar 2010 at 5:27pm |
Hey everyone!
Just stumbled across this place, as I'm starting to look for a custom built computer. Just looking to see if I can get any ideas here, as there seems to be a lot of really cool, knowledgeable people here. I'd originally thought about using my old computer and putting one together myself, but I don't trust myself yet. So, here goes. I currently have a Dell XPS 400. I hate Dell. Never going back there again. This time around, I'm looking to spend no more than $1500 (I know, cheap), but I want more bang for my buck. 1) Monitor size and general resolution most games will be played on
I have a standard 17" Dell monitor that's attached to my system via plug&play. Must've forgotten to install the software after my last reformat. Will I be able to use this monitor in a new system? 2) Budget
I have a friend who said he put a really nice computer that would blow mine away for about $500. I think he might've had a few parts laying around. Either way, my budget would be $1500 or significantly less than that. :P 3) whether you will use any equipment from your last computer on
the new computer (keyboard, mouse, speakers, monitor etc) that way we
can budget that out of the build
I hope to use the monitor (see above), keyboard, mouse, speakers will all be used. 4) General uses to be done on the computer. (gaming, college work,
internet etc.) MMORPG gaming, music editing (sometimes recording), internet, word-processing. The gaming is by far the largest strain on the system. |
Quote Reply Posted: 05 Mar 2010 at 5:38pm |
what resolution does that 17" have?
Here you go Ticket# 390204 --- Price: $1824 (To see this build click here) Price after current promotion $1824 Copy of Specifications: Chassis Model: Special Deal Hot Seller - HAF 922 Exterior Finish: - Not Available Trim Accents: - Not Available Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 Micro Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire) System Memory: 3GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - Not Available Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - Not Available Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x ATI Radeon HD 5850 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors) H20 Tube Color:- Not Available Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - Not Available Chassis Mods: - Not Available Noise Reduction: - Not Available Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - Not Available Boost Memory: - Not Available Boost OS: - Not Available Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - Not Available Office: - Not Available Benchmarking: - Not Available Install/Test Game: - Not Available Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty you may want to upgrade the ram to 6GB down the road. Edited by DST4ME - 05 Mar 2010 at 5:40pm |
elepheagle
Quote Reply Posted: 05 Mar 2010 at 5:41pm |
1152x864 is what I have it set at. Usually game 1200x800, I think.
elepheagle
Quote Reply Posted: 05 Mar 2010 at 5:43pm |
That looks nice...now any way to knock about $400 off of that price without losing too much? :)
Quote Reply Posted: 05 Mar 2010 at 5:47pm |
for that res we can drop the gpu to a lower one:
Here you go Ticket# 390207 --- Price: $1652 (To see this build click here) Price after current promotion $1652 Copy of Specifications: Chassis Model: Special Deal Hot Seller - HAF 922 Exterior Finish: - Not Available Trim Accents: - Not Available Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 Micro Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire) System Memory: 3GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Expansion Bay: - Not Available Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - Not Available Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 22x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x ATI Radeon HD 5770 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors) H20 Tube Color:- Not Available Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - Not Available Chassis Mods: - Not Available Noise Reduction: - Not Available Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - Not Available Boost Memory: - Not Available Boost OS: - Not Available Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - Not Available Office: - Not Available Benchmarking: - Not Available Install/Test Game: - Not Available Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty |
elepheagle
Quote Reply Posted: 05 Mar 2010 at 5:57pm |
Ok, I've played around with the build a little bit more and came up with this build. Do I have anything on there I don't need? In your opinion, what would be the differences I would notice after having them out of the box and hooked up. What about in terms of future upgrades and compatibility?
Thanks for your help. Edited by elepheagle - 05 Mar 2010 at 6:00pm |
cheebamaster
Groupie Joined: 10 Feb 2010 Online Status: Offline Posts: 134 |
Quote Reply Posted: 05 Mar 2010 at 6:04pm |
Make sure you grab the "Free" processor OC...you chose they pay one ;p
If you can muster out the extra hundred the 5770 is worth it. |
elepheagle
Quote Reply Posted: 05 Mar 2010 at 6:10pm |
Thanks, Cheeb.
Exsidium
Groupie Joined: 13 Feb 2010 Online Status: Offline Posts: 166 |
Quote Reply Posted: 05 Mar 2010 at 6:11pm |
You forgot to change the overclock to the free one. You could use the money from that to upgrade the power supply to the corsair. That processor is solid, I have it myself. That being said, the build DST picked is much more solid and upgradable. A budget is a budget though so do what you have to, just trying to inform ya. The case you chose doesn't have good airflow just be warned. You could stick with the DS psu (would highly recommend corsair though) and upgrade to the haf 922.
elepheagle
Quote Reply Posted: 05 Mar 2010 at 6:15pm |
Ah, yes, I see that now. Thanks for your reply.
Exsidium
Quote Reply Posted: 05 Mar 2010 at 7:02pm |
Oops! Didn't realize cheeb had already pointed that out. Good luck with your build, just try to keep upgradability in mind.. Gpu and ram are quick easy upgrades. Cpu, mobo, psu, tower.. These you don't wanna sacrifice.
Quote Reply Posted: 05 Mar 2010 at 7:13pm |
I don't like the case, it has very little airflow and room to grow, I don't even think the nvidia cards will fit in there.
the build I gave you has 2GB more ram, better psu, better gpu, better cpu cooler, win7 pro so you have xp mode, and on top of all of that, the x58 platform you can upgrade your cpu in a few years to a 6 core coming out this year, the cpu is the brain of your pc so a new cpu is like a new pc, but for $200 to $400 and thats in 3 years, the p55 platform does not support cpu upgrade to a 6 core. all of that for $100, so my question is, knowing all of that do you still want to go with the p55? if so then we need to change some stuff in that config, and just so you know by the time we do, you are gonna be maybe $40 off the price of my config. Edited by DST4ME - 05 Mar 2010 at 7:13pm |
elepheagle
Quote Reply Posted: 06 Mar 2010 at 1:44am |
DST-
I appreciate the time you've taken to take a look at my inquiry. I'm a novice when it comes to hardware. Since my last post, I've looked into things a bit more, and what you are saying makes complete sense. It was the price tag that got me; my problem is that, although I can afford a system, it's a want and not a need. That's the part I wrestle with. :P Consider this thread closed. |
Quote Reply Posted: 06 Mar 2010 at 4:52am |
well all I can tell you is that, when times where tough for me back in the day, and I could not buy a new pc ever 3 or 4 years, being able to upgrade the cpu was a huge deal to me, since by just spending couple of hundred dollars I could upgrade the cpu, and the pc's performance would be better and like a new pc to me, so that was/is to me more of a matter of need then want, I think that many people out there can't afford to buy a new pc every 3 or 4 years, for those people I think its best to go with a an x58 platform, mainly cause the cpu can be upgraded to the new 6 core cpus coming out this year. this can help people own their pc for 6 or 7 years and really enjoy it and have a better performing pc after 3 or 4 years, and I'm sure you know in that amount of time, apps get more demanding, and one's pc seems slower, so a new boost of power for cheap is a well coming if not a need around that time.
thats the way I looked at it, yes you are spending a $100 here and maybe say $300 in 3 years, but you get a faster, better performing pc in 3 years, that much better then paying $1600 in 3 years to get a new pc, or just wishing you could get a new pc but being stuck with the one you have without a cpu upgrade. maybe that helps, it was my pleasure and good luck |
