Looking for help with build.
Post Date: 2009-11-22
stjohnson70 View Drop Down
  Quote stjohnson70 Quote  Post ReplyReply bullet Topic: Looking for help with build.
    Posted: 22 Nov 2009 at 10:31pm
I am new to these forums and like what i have read so far about Digital Storm in general. I would like to get some ideas on configurations. I am looking to stay fairly cheap on this computer and hope to have room to grow. I will be using it for gaming and the internet and would like to keep the cost around $1500. I will be purchasing a new monitor more then likely in the 24 range with no more then 1900 X 1200 resolution. I all ready have in my possesion speakers, keyboard, and mouse.
Thank you in advance for any help you can provide.
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 23 Nov 2009 at 2:19am
At $1500 you wont have much room to grow in the future as some components like the power supply will most likely need to be upgraded.
Here is what I would recommend, it is a little over your budget but will perform excellently with the new monitor you are purchasing.
Ticket Number: 356352
As Configured: $1730.00
Trim Accents: - Not Available
Processor: Intel Core i5 750 2.66GHz (Quad Core)
Motherboard: EVGA P55 LE Edition (Intel P55 Chipset)
System Memory: 4GB DDR3 1333MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 275 896MB (Includes PhysX Technology)
Extreme Cooling: AIR: Stage 1: High Performance Cooler (Compatible With ONLY i5/AMD Processors)
Enhancements: - Not Available
Chassis Mods: - Not Available
Boost Memory: - Not Available
Boost OS: - Not Available
Office: - Not Available
Benchmarking: - Not Available
If that is too far over your budget then you can drop the video cards to 1x NVIDIA GTX 275 and the price will drop to $1462.
Edited by venom - 23 Nov 2009 at 2:20am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Nov 2009 at 6:57pm
also with that platform (p55) you can't upgrade the cpu either.
see if you can raise your budget and go with a 920 and x58 platform so that you can upgrade to the new 6 core cpu coming out in 2010, whenever you are ready to upgrade to it down the road.
