Looking for help with my first build
Post Date: 2012-01-24
poppinjae View Drop Down
  Quote poppinjae Quote  Post ReplyReply bullet Topic: Looking for help with my first build
    Posted: 24 Jan 2012 at 8:26am
$2000, preferably including monitor and shipping but that isn't completely necessary, they could be on top of it. Don't need a mouse or keyboard
To be able to last for at least a few years, play games like Diablo 3, Skyrim, and Guild Wars 2 as well as possible, within budget. Also looking to have dual monitors eventually
Mostly gaming and video watching. Often at the same time.
Its fairly dusty here, and would prefer it to run as quietly as possible.
Thank you for any help you can give.
kane860 View Drop Down
  Quote kane860 Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 8:34am
what is the native resolution you will be gaming at?
System:
HAF X942 / i7 3930k 6-core cpu / ASUS P9x79 Deluxe MOBO
16gb DS ram / Corsair 1050HX PSU / Two - Intel 320 series 120gb SSD's
WD Caviar Black 1TB HDD / GTX570 2.5gb GPU / Noctua D14 Cooler
  Quote poppinjae Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 8:47am
Wouldn't that depend on what monitor I get?
  Quote kane860 Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 9:11am
yea lol  any ideas?
System:
  Quote poppinjae Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 9:17am
1920 x 1080?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 10:18am
Hi poppinjae....For your budget and gaming resolution and assuming monitor is 24" or less the ODE 1 is the best bang for the buck.  $1539   Hard to beat the price.
If you wanted to go to $2000 or so, you could get a custom build with better psu, case and mobo and overclock but the gaming performance would be about the same.
Example is build # 647484   $1991
Motherboard: ASUS P8P67 PRO (Intel P67 Chipset) (New B3 REV 3.1 Revision)
Hard Drive Set 1: Operating System: 1x (500GB Seagate Barracuda (7200 RPM) (16MB Cache) (Model: ST500DM002)
Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) (EVGA Edition)
For another couple hundred you get a build capable of sli ( dual graphic cards ).  Just up the mobo and psu to 1050.  Add a gpu later.
Hope this helps..Good LuckBig%20Smile
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 1:59pm
If your games don't utilize sli correctly then ode 1 or the build bprat22 posted is what you want, if they do sli then we need to change stuff around and budget will need to be stretched, or we can go with bprat22's build but make it so that it supports sli.
  Quote poppinjae Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 3:11pm
Thanks for the advice, I'm thinking that I might go with the ode 1.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 3:42pm
Good choice.     Tough to beat the price and you'll have great gaming.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Jan 2012 at 8:55pm
Our pleasure and good luck
ode 1 is a good choice for its price.
Edited by DST4ME - 24 Jan 2012 at 8:55pm
