Lost IE8 32 bit in Win 7 64 bit...help!!
Post Date: 2010-12-09
ziggy View Drop Down
  Quote ziggy Quote  Post ReplyReply bullet Topic: Lost IE8 32 bit in Win 7 64 bit...help!!
    Posted: 09 Dec 2010 at 8:50pm
My grandson managed to screw up my pc today when I wasn't looking. I have NO 32 bit IE8 only 64 bit.I don't even have the shortcut for it, In the Internet Explorer folder I have iexplore BUT not ieexplore.exe. When I click on it nothing happens.
I tried the the "Turn windoes features on or off" for Internet Explorer but it did not work .Still NO 32 bit browser. I ran SFC but to NO avail. Please don't tell me I will have to reinstall my Win 7 64 bit os again!! Any tech help would be GREATLY appreciated.
Edited by ziggy - 09 Dec 2010 at 8:51pm
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Dec 2010 at 9:07pm
  Quote ziggy Quote  Post ReplyReply bullet Posted: 09 Dec 2010 at 9:11pm
When I try to install it it says"IE8 is not supported by this OS"
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Dec 2010 at 9:45pm
just try getting ie 9 from the same page then
dunno why 7 isnt on the list
its beta, but if the feature fix didnt work for you, dunno what else you could do
  Quote ziggy Quote  Post ReplyReply bullet Posted: 09 Dec 2010 at 9:51pm
You are not to be able to uninstall IE 8 in Win 7.Tried IE 9 64 bit works.Tried IE9 32 bit and get the same message I did when I tried to install IE8 32 bit. It says it doesn't support this OS. I uninstalled IE 9 64 bit and it reverted me back to IE * 64 bit.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 09 Dec 2010 at 11:51pm
wierd, i have no idea what that kid did, but it must have been pretty bad, time to switch to chrome?
Edited by !ender_ - 09 Dec 2010 at 11:52pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Dec 2010 at 2:59am
Do you see ie in this location at all?
C:\Program Files (x86)\Internet Explorer\iexplore.exe
  Quote ziggy Quote  Post ReplyReply bullet Posted: 10 Dec 2010 at 7:23am
Yes I do but when I click on it nothing happens.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Dec 2010 at 7:25am
You have a good upto date AV you can scan your system with?
  Quote ziggy Quote  Post ReplyReply bullet Posted: 10 Dec 2010 at 9:17am
http://iefaq.info/index.php?action=artikel&;cat=42&id=133&artlang=en.
This is where I found my fix.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Dec 2010 at 3:35pm
Ya I was gonna make sure your pc is clean before I suggest that file, I also was not sure if it would fix your problem, but I'm glad it did, check your pc for viruses anyways.
  Quote ziggy Quote  Post ReplyReply bullet Posted: 12 Dec 2010 at 7:09pm
I did it's clean
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 13 Dec 2010 at 12:31am
Good news
