Lowest Build for Max Crysis
Post Date: 2009-03-28
Instinct View Drop Down
  Quote Instinct Quote  Post ReplyReply bullet Topic: Lowest Build for Max Crysis
    Posted: 28 Mar 2009 at 12:25am
I am planning to buy a gaming desktop soon and would like to run Crysis in max (with at least 2x AA and 4x Anistrophic Filtering, thought 4x and 8x is more preferred respectively).  I will most likely start playing it at 1680x1050 and start going up to 1920x1200 or 1920x1080 if I decide to upgrade my monitor.  I chose Vista 32 bit because I may decide to play other games that are only 32 bit compatible.  I was wondering if my RAM is good enough?  I also heard you need a certain amount of CPU to fully operate your GPU at it's max (might be the term bottlenecking?).  Should I upgrade my CPU to the 940? I mean DS will overclock it, but will it be enough to maximize my GPU performance?  Should I use 2x 295 or 3x 285 at those resolutions for Crysis? I am around at a $3k budget.
System Memory: 3GB DDR3 1333MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Card Reader: - No Thanks
Video Card: 2x SLI Quad (NVIDIA GeForce GTX 295 1.792GB) (Includes PhysX Technology)
Windows OS: Microsoft Windows Vista Ultimate
I hoping to run Crysis at 60+ FPS, but if 1920x1200 isn't possible with that FPS, I'll just stay with 1680x1050.  Can anyone estimate how much FPS I will get with this desktop config?
I can't find the 230mm BLUE LED front fan :[
Edited by Instinct - 28 Mar 2009 at 12:42am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 12:29am
ticket number please, there is very little difference between 3 x 285 and 2 x 295 in all games, except for crysis, 3 x 285 will provide 20 more fps at your resolution.
Edited by DST4ME - 28 Mar 2009 at 12:30am
  Quote Instinct Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 12:36am
The ticket number is 264278.  I would definitely add 100 dollars just to get 20 FPS more, as it is in within my budget.
Edited by Instinct - 28 Mar 2009 at 12:39am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 1:12am
well you also need more ram
here you go Ticket# 264284 --- Price: $3551 (To see this build click here) Price after current promotion $3301
System Memory: 6GB DDR3 1333MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Video Card: 3x SLI Triple (NVIDIA GeForce GTX 285 1GB) (Includes PhysX Technology)
LCD Display: - No Thanks
I recommend you lc the cpu with a tri or quad sli system.
here is Crysis WARHEAD with the mentioned cards:
Edited by DST4ME - 28 Mar 2009 at 1:12am
  Quote Instinct Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 2:02am
Thanks for the graphs.  So I guess my CPU is fine for Crysis at max?  Why would I need more RAM if I'm using 32 bit Vista, it doesn't support more than 4 gb right ?  I chose 32 because I still want to play css and other old games.
EDIT: It seems CSS and many of my other games support 64 bit, looks like I'll be upgrading to 64 and some RAM :D
You also said:
"I recommend you lc the cpu with a tri or quad sli system. "
I don't understand, what should I upgrade? And does anyone have a new link for the 230mm Blue LED fans for the HAF?
Edited by Instinct - 28 Mar 2009 at 2:44am
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 2:59am
if you have 3 graphics cards youll need 64 bit just for 3gb of DDR3
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 4:37am
as SP said, you will need vista 64bit regardless, you have 3GB of ram in your config and 3.584GB of ram in 2 x 295, for a total of 6.584GB of ram.
in my config there is even more ram, you have to go with vista 64bit, you have no choice, and a good thing too
230mm Blue LED
I'm recommending you choose frostbite cooling for your CPU, since you are going to go either quad sli or tri sli with the GPUs, thats a lot of heat.
  Quote Instinct Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 11:21am
If I choose frostbite cooling for my CPU, can I still upgrade my CPU or GPU?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 28 Mar 2009 at 2:30pm
yes of course you can
  Quote Instinct Quote  Post ReplyReply bullet Posted: 30 Mar 2009 at 7:09pm
Originally posted by DST4ME
230mm Blue LED
Will there be instructions on how to install the 230 mm in the package?  I heard you also bought one before, how easy is it?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Mar 2009 at 7:16pm
no I didn't buy one, I'm still waiting on parts I want for my PC.
there will be no instructions however here is the manual for the HAF which is self explanatory and should help you install it
Bouke285 View Drop Down
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 17 Apr 2009 at 11:18am
Just so you know crysis isnt that great so dont base your build on it.
I know the plans I have for you, declares the Lord, plans to prosper you and not to harm you, plans to give you hope and a future." (Jeremiah 29:11)
issues1975 View Drop Down
  Quote issues1975 Quote  Post ReplyReply bullet Posted: 17 Apr 2009 at 11:39am
230mm Blue LED
It is very simple to install the front fan. Probably took me 5 minutes, if that.
I think many people like to use Crysis as more of a benchmark when building systems than actually building a system to play 1 game.
If you're system can play Crysis maxed there's a good chance it will play just about any game released over the next year with max settings...
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 17 Apr 2009 at 2:00pm
If you really want to test some thing try Age of Conan on max the graphics are amazing even for an mmorpg. I had no trouble with crysis on max but when I played this I had to bump down the settings.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2009 at 2:48pm
Bouke285 you had to put your settings down probably because age of conan does not support sli but crysis does, so in short age of conan is not a good game to base your system on.
  Quote Bouke285 Quote  Post ReplyReply bullet Posted: 17 Apr 2009 at 4:12pm
I only have a single graphics card atm, I'm not saying crysis looks bad it looks amazing, but i'm saying it's not that hard to run my $1500 pc ran it perfectly well. My point is you dont need to spend tons of money on your pc to beable to play crysis or any other game on max settings.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Apr 2009 at 4:17pm
depending on your resolution do you do, for example at 1900 x 1200 to run many games on high settings including crysis you will need a dual sli
look at the fps difference between 1 x 260 and 1 x 295, huge difference, cause the 295 is a dual sli internally.
at the end of the day how much money you need to drop on gpu depends on what games you play and your resolution, if you are below 1600 x 1200 then ya a single card will do
