Lumos Build Advice
Post Date: 2019-10-21
Crazy Canuck View Drop Down
  Quote Crazy Canuck Quote  Post ReplyReply bullet Topic: Lumos Build Advice
    Posted: 21 Oct 2019 at 3:31pm
$3000-$4000
To be able to run most games, Tomb Raider, The Witcher, Assassins Creed and all new games at high to ultra settings.
Mostly gaming.
Looking for a really quiet gaming computer. Will use with an Acer Predator X34P curved monitor 3440 x 1440   120hz
Saved Ticket #: Config ID 2637431
Looking for some guidance from the experts on my build. I purposely selected a low end video card that I plan on swapping out for my current MSI Gaming 1080 ti. My thought was to upgrade the 1080 ti later when I can no longer play at high/ultra settings. Here's the configuration I selected :
Motherboard: MSI MPG Z390 GAMING PRO CARBON AC (Wi-Fi) (Intel Z390 Chipset) (Up to 3x PCI-E Devices)
System Memory: 32GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 970 EVO PLUS) (NVM Express)
Graphics Card(s): 1x GeForce RTX 2060 SUPER 8GB (VR Ready)
Extreme Cooling: H20: Stage 2: Corsair H115i PRO - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance)
Airflow Control: - No Thanks
CPU Boost: Stage 2: Overclock CPU - Up to 5.1GHz on All CPU Cores
Mouse Pad: - No Thanks
Branded Gear: - No Thanks
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 21 Oct 2019 at 5:32pm
Looks like a very solid Lumos build to me, and I like the logic of using your GTX 1080 Ti GPU.   Still a strong top end contender GPU that was also given Ray Tracing along with the RTX cards so there is still some time to use this excellent GPU.   I own one I use on an older 2011 DS build to keep it playing strong current titles at high frames on a 2K Dell 34" panel. This is the longevity benefit of buying the very top end NVidia cards...
Be aware that DS will work with you if there are certain components you want ordered.   Not yet offered by DS but quite available out there is the bigger Corsair Hydro Series H150i PRO RGB 360mm (3 x 120mm fan) cooler, and it's compatible with the front mount in the Lumos (Corsair Crystal 570X ATX case).   All you have to do is ask them about getting it for your build.   The 9900K can be a warm Overclocker so short of full HydroLux Pro that would be what I would use for an AIO selection and max your cooler.
  Quote Crazy Canuck Quote  Post ReplyReply bullet Posted: 22 Oct 2019 at 3:23pm
Thanks HockeyBuck for the quick response. I have another question about cable management. I'm wanting to order the exotic cable management with the cable combs etc, but the RTX 2060 super only requires one 8 pin power connector, but my 1080 ti requires an 8 pin and a 6 pin power connector. I know the power supply probably has extra power management cables, but am concerned about trying to thread another one to the card after the fact and ruin the beautiful cable management. If I contact DS when I order, do you think they would thread an extra 8 pin power connector next to the other one, so I can easily swap out the cards and plug in the correct connectors for my 1080 ti ?
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 22 Oct 2019 at 4:47pm
Yes, just ask them and that’s easy for DS to do.
