Lynx - Level 4 ordered and reviews
Post Date: 2020-05-29
Themailman View Drop Down
  Quote Themailman Quote  Post ReplyReply bullet Topic: Lynx - Level 4 ordered and reviews
    Posted: 29 May 2020 at 11:05pm
Ordered a Lynx - Level 4 build on the 26th of May, waiting for it to process still. Looking forward to it arriving. Planning on pairing it with a 144hz G-synch monitor, any suggestions on one that wont break the bank :).
Edited by Themailman - 29 May 2020 at 11:07pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 30 May 2020 at 5:24am
This article explains a lot and may help you find a monitor less expensive than the full-on proprietary G-Syncs.
https://www.rockpapershotgun.com/2020/03/04/g-sync-compatible-monitor-list-how-to-enable-g-sync-on-a-freesync-monitor-2020/
Happy hunting!
John18 View Drop Down
  Quote John18 Quote  Post ReplyReply bullet Posted: 30 May 2020 at 12:56pm
I have a Lumos arriving Monday with a RTX 2080 Super onboard. I personally opted for the LG 27GL850. It is "G-Sync Compatible" and should work for my needs.
Happy Hunting...again.
ThePinkGoat View Drop Down
  Quote ThePinkGoat Quote  Post ReplyReply bullet Posted: 30 May 2020 at 1:55pm
I have that card you can play anything in Max, Ultra settings. The fans will not turn on until you hit 50 so don't think they're not working like I did when I started using that card. Mine is a ASUS Super. BTW Lumos is the best case they offer, looks the best iMHO and it gets little to no dust inside at all.
  Quote Themailman Quote  Post ReplyReply bullet Posted: 05 Jun 2020 at 7:06am
Order was processed a few days ago, making progress
  Quote John18 Quote  Post ReplyReply bullet Posted: 05 Jun 2020 at 1:00pm
I have been downloading software and configuring the computer.
I did take some time last night and played Overwatch on Ultra at 1440p and 144 Hz, never topping 79 degrees. When just working on normal things I do not hear the computer. If I am gaming I still haven't heard it over the game.
I downloaded Star Wars: Jedi Fallen Order and will likely try that this weekend. We'll see how that does, but I expect about the same amount of quietness.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 06 Jun 2020 at 3:21am
John18, don't forget to review the game, too!
anhy123 View Drop Down
  Quote anhy123 Quote  Post ReplyReply bullet Posted: 29 Jul 2020 at 1:05am
So I ordered my Lynx Level 2 last Friday on the 22nd & it entered stage 1 on Monday... I was wondering since mine isn’t a custom order will it ship out faster since it’s pre-built? I’m just alittle confused why it would take so long if it’s already pre-built... all they would have to do is test it and ship it after determining if it’s solid product... thanks
