Lynx Rear Fan Lighting
Post Date: 2020-06-08
chargerstorm View Drop Down
  Quote chargerstorm Quote  Post ReplyReply bullet Topic: Lynx Rear Fan Lighting
    Posted: 08 Jun 2020 at 3:58pm
So I recently received my Lynx PC and I noticed the rear fan spinning but not lighting up like the three front fans. Is the rear fan supposed to be non-rgb or is there a cable unplugged by mistake?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 09 Jun 2020 at 2:38am
Looks like that one should be lit, too. Headers can come loose in shipping. If you have to go deep to look, unplug from the wall. Press the on button 5 seconds to discharge capacitors. Remove the side panel and touch metal on your case to be grounded before you go in there. Luck.
  Quote chargerstorm Quote  Post ReplyReply bullet Posted: 09 Jun 2020 at 5:03am
I took a look to make sure everything was pushed in and It still does not work. Do you happen to know where exactly the fan plug is? I check the fan modular box as well.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 09 Jun 2020 at 6:43am
Sorry, I do not. Use your DS support, they may need to send you a new fan.
Try
[email protected]
Edited by Cretae - 09 Jun 2020 at 6:50am
