Lynx Top Fans: One BARELY fits, will it burn up?
Post Date: 2023-02-18
CrivRex View Drop Down
  Quote CrivRex Quote  Post ReplyReply bullet Topic: Lynx Top Fans: One BARELY fits, will it burn up?
    Posted: 18 Feb 2023 at 7:43pm
Hello all! I got some case fans for my Lynx and one of the top fans is just barely touching (almost perfect fit) the part called "Dr. mos." I attached a link to the photo.
I tested under peak temperatures and it was barely warm but not burning hot. The board is an Asus X570-Pro and fan is a Cooler Master MF120 Halo.
Will it be ok or too risky? Suggestions or past experiences. thx!!!
Board Photo
DS Lynx
ASUS PRIME X570-P
AMD Ryzen 5 5600X
NVIDIA RTX 3060Ti 8GB
32GB Corsair Vengeance DDR4
DS-Vortex Liquid CPU Cooler
  Quote Cretae Quote  Post ReplyReply bullet Posted: 19 Feb 2023 at 7:09am
Looks like more clearance than you describe. That structure at the bottom of the arrow is a heat sink to spread and dissipate heat. That you have a fan nearby is a good thing.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 19 Feb 2023 at 1:56pm
I was expecting significantly less clearance based on your description. It will be fine. Strong
  Quote CrivRex Quote  Post ReplyReply bullet Posted: 19 Feb 2023 at 2:10pm
Sorry folks, I should explain better. That line hight IS the hight of the fan itself. The fan will lay right on it. Clearance measurement is gonna be about 1/16 of an inch. Just making sure so I don’t start a fire lol. Sorry for the confusion. Thnk you!
DS Lynx
ASUS PRIME X570-P
AMD Ryzen 5 5600X
  Quote CrivRex Quote  Post ReplyReply bullet Posted: 19 Feb 2023 at 9:10pm
Ended up installing it and just monitoring it long term to see if there’s signs of burn marks. Thanks!!
Fan Installed:
https://drive.google.com/file/d/1zCPTwUz5soF_glYE3BqI3W01opaf4Msc/view?usp=drivesdk
DS Lynx
ASUS PRIME X570-P
AMD Ryzen 5 5600X
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Feb 2023 at 6:04am
I see what you're saying. The fan itself generates little heat, and the heat sink it's almost resting on is dissipating heat all around. Again, I think having a fan right there is safe and helpful. Do keep an eye on it, though.
  Quote CrivRex Quote  Post ReplyReply bullet Posted: 20 Feb 2023 at 6:07am
Definitely!! thx!
DS Lynx
ASUS PRIME X570-P
AMD Ryzen 5 5600X
