Maelstrom Fan
Post Date: 2010-06-25
Rockill View Drop Down
  Quote Rockill Quote  Post ReplyReply bullet Topic: Maelstrom Fan
    Posted: 25 Jun 2010 at 6:21pm
I recieved my DS gaming pc today, and everything is running great. However, the 240mm fan on the side of the case was unplugged and I can't seem to find anywhere to plug it in, I do have the stage 1 liquid cooling upgrade.
rodsmith View Drop Down
  Quote rodsmith Quote  Post ReplyReply bullet Posted: 25 Jun 2010 at 6:32pm
when I saw the topic,I took it to mean that you were a fan of that Maelstrom case,but instead you have an actual issue with the fan inside. I would change the topic so that you might get a faster response from one of the great folks who work at DS !
Edited by rodsmith - 25 Jun 2010 at 6:33pm
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Jun 2010 at 6:56pm
You need to plug it on one of the fan headers on the motherboard.
It get's unplugged because you need to remove the side panel to take out the internal foam padding.
If you look up a diagram on your motherboard, it will show you where there are a few fan headers that you could possibly plug the fan into.
Or, you can always call us and we can walk you through it too. Big%20Smile
  Quote Rockill Quote  Post ReplyReply bullet Posted: 26 Jun 2010 at 11:27am
There does not seem to be any open spaces on the motherboard to plug in the fan, it looks like the motherboard doesn't even have the right slot to plug it in
  Quote Rockill Quote  Post ReplyReply bullet Posted: 26 Jun 2010 at 11:42am
Nnvm I figured it out
  Quote Cretae Quote  Post ReplyReply bullet Posted: 26 Jun 2010 at 9:07pm
Go, Rockill! Big%20Smile
Coolermaster Storm Sniper
Intel Core i7 930 3.8GHz OC
EVGA X58 LE
6GB DDR3 1600Mhz Ram
750W Corsair
1TB HDD
1x ATI RadeonHD 5870 1GB
Noctua Dual 120mm
