Manual Fan Controllers
Post Date: 2010-02-03
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Topic: Manual Fan Controllers
    Posted: 03 Feb 2010 at 10:46pm
I need to do some upgrading on case fans for my Silverstone Raven RV01. What I need to know is how exactly do manual fan controllers work. You know, the ones with a knob that you hook up your fan to. Does it allow you to switch between speeds higher or lower than the current speed? I'm going to replace my current fan to a blue LED 700 RPM set speed fan. Will a fan controller hooked up to it allow it to switch between 500~1300 rpm like most controllable fans? Or another speed variation?
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Feb 2010 at 12:47am
if all your fan can do is 700 then that is as high as its gonna go.
get yourself some quiet fans that have a good cfm, and you can control them a fan controller.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 04 Feb 2010 at 9:11am
what? DST you don't overclock your fans? Smile
