Marauder level 4 or bolt level 2
Post Date: 2012-10-30
Brud2000 View Drop Down
  Quote Brud2000 Quote  Post ReplyReply bullet Topic: Marauder level 4 or bolt level 2
    Posted: 30 Oct 2012 at 6:18pm
from a pure technical stand point all i want is gaming at high quality at a high fps i have a 1920x1080 monitor
I won't miss.
  Quote Alex Quote  Post ReplyReply bullet Posted: 30 Oct 2012 at 7:33pm
The Marauder is going to be slightly faster due to the better graphics card, however, the Bolt is overclocked.
It's a touch choice, both are good, it'll depend if you want a small slim tower or a big one.
DarkSpace View Drop Down
  Quote DarkSpace Quote  Post ReplyReply bullet Posted: 30 Oct 2012 at 9:12pm
You can't really go wrong with either one becuase overall they are pretty simmilar.
  Quote Brud2000 Quote  Post ReplyReply bullet Posted: 30 Oct 2012 at 9:51pm
But the marauder is more expensive however the bolt might overheat p.s the longest i play a game is like 3 hours at a time
I won't miss.
LaneHayes View Drop Down
  Quote LaneHayes Quote  Post ReplyReply bullet Posted: 01 Nov 2012 at 11:56am
I doubt the bolt is going to 'overheat.' Usually things overheat within 5-15 minutes or they don't overheat for years (or until something changes in the cooling).
If you're worried ab degredation due to constant near overheating like I have witnessed in the last 2 gaming laptops I've had, I get your concern but I dont think a 3.6 inch thick tower is going to have the same issues as a .5 inch thick laptop that only has half of its surface area exposed.
I haven't looked closely at the Bolt but if its still mostly "open" in that you can alter parts on your own like a dreadnaught or marauder, I say go for it. If its mostly proprietary parts (which I highly, highlyhighlyhighlyhighly doubt DS is going to do, ever) then I'd 100% go with the marauder. Dell/Gateway and most recently Apple scared me away from proprietary components for life.
  Quote Alex Quote  Post ReplyReply bullet Posted: 01 Nov 2012 at 12:04pm
The Bolt does not overheat, if it did, our team would not be selling it.
Arenier View Drop Down
  Quote Arenier Quote  Post ReplyReply bullet Posted: 03 Jan 2013 at 10:31am
I had to choose between the Bolt and the Marauder. I ended up getting the Marauder. I don't know about you but when it comes to cleaning out a computer and/or upgrading it, I like to have space to move in between parts. Anyways both computers are very similar.
-John 3:16
