Memory card reader
Post Date: 2009-06-07
Achtung91 View Drop Down
  Quote Achtung91 Quote  Post ReplyReply bullet Topic: Memory card reader
    Posted: 07 Jun 2009 at 11:12am
I was wondering if someone here could help me out.  I bought an internal memory card reader, and am having difficulty figuring out where to plug in the 9-pin connector on my mobo.  Thanks in advance for the help.
System Memory: 3GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card(s): NVIDIA GTX 275
Liquid Color: - Not Applicable, I do not have a H20: Stage 3 Cooling System Selected
CPU Boost: - No Thanks, Please do not overclock my processor
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 4:04pm
that is called a USB 2.0 Header Connector, if I'm not mistaken, there should be 2 of them on your mobo and they are blue if I'm not mistaken
if you can give me the make and model of your reader I can double check
Edited by DST4ME - 07 Jun 2009 at 4:05pm
  Quote Achtung91 Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 4:14pm
It's just some cheap reader I bought for $15, and doesn't even have a label on it. I'm almost certain you are correct with it being a USB 2.0 plug.  Problem is they are both in use.  I think one of them is connected to sata/usb plugs on the Cooler Master HAF case.  I'm not sure what the other one is hooked up to as DS did the wiring.  Thanks for your response and help :)
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 4:29pm
best call DS for that for that to be sure then.
NullForce View Drop Down
  Quote NullForce Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 6:22pm
Kind of an unrelated question regarding the memory card reader...
The internal option is the one installed in the case right?
hihi
Mikey14 View Drop Down
  Quote Mikey14 Quote  Post ReplyReply bullet Posted: 07 Jun 2009 at 6:23pm
yep.
  Quote NullForce Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 11:38am
Originally posted by Mikey14
yep.
Geek
hihi
  Quote Achtung91 Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 5:24pm
Yes
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 08 Jun 2009 at 7:31pm
yes it is.
Broken%20Heart
