memory timings -- help/suggestions
Post Date: 2009-01-14
Snakeyes View Drop Down
  Quote Snakeyes Quote  Post ReplyReply bullet Topic: memory timings -- help/suggestions
    Posted: 14 Jan 2009 at 7:18am
I have an older DS System which, with some minor modifications in the cooling system, runs stable and fairly cool (Prime95, Orthos, Memtest etc). Would there be any benefits and tightening up my memory settings, and if so I would appreciate any suggestions on timings. I have played with lower multiples and higher FSB's but have achieved maximum stability using the settings below. Any suggestions would also be appreciated regarding the CPU settings.I have some headroom in both CPU core and DIMM voltages.
Thanks.
Intel Core2 Quad QX6800 2.93GHz occd to 3.467GHz @1.45v 35/55C noload/load
eVGA nVidia nForce 680i SLI
1000W PC Power & Cooling Turbo-Cool
2GD DDR2 Corsair 1066MHz Dominator (5-5-5-15) @ 2.04v
Two 150GB WD Raptors (10k) in Raid 0
One 150GB WD Raptor (10k)
Samsung  LightScriber Writemaster
Creative X-Fi XtremeGamer\
Liquid cooled CPU & GPUs 45/58C Noload/load
3DMark06--17592 @CPUx13-FSB 1067-GPU@661x1042
Snakeyes
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 2:45pm
If your system is stable then stick with what you got, you won't notice the difference in ram timings
XpubuX View Drop Down
  Quote XpubuX Quote  Post ReplyReply bullet Posted: 14 Jan 2009 at 3:02pm
the best timmings I've been able to reach with that ram is 5,4,4,15
the highest stable oc I can reach is only 1100  Both of these make little to no difference so I would just leave your settings alone
  Quote Snakeyes Quote  Post ReplyReply bullet Posted: 15 Jan 2009 at 10:01am
Appreciate the feedback guys.I will leave my timings as is and I am tempted by the E8600 and its headroom.
Thanks
Snakeyes
