Mineral oil submerged PC
Post Date: 2010-10-12
AmbientChong11 View Drop Down
  Quote AmbientChong11 Quote  Post ReplyReply bullet Topic: Mineral oil submerged PC
    Posted: 12 Oct 2010 at 10:04pm
From the testing done by this company, it looks pretty amazing. What are your thoughts on it (v1, v2, and v3)?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 10:05am
Looks cool, works like poop. does not cool worth a darn.
MagiK View Drop Down
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 12:24pm
You sure about the cooling Justin?  With a 3x3 Radiator I dont see why it would not work at least as well as a decent conventional LCS system
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 12:36pm
yep, works like crap.
temps were outrageously high, CPU temps were stupid high, and the GPU's were crazy high. and the temps that are most over the top they don't show, the V regs.
with that low of an overclock, temps should never break 30C with that temp monitor program, 40C is what Realtemp would show. appx. for $700 bucks, and have poorer temps than high end air cooling temps, is pure crap.
Edited by justin.kerr - 13 Oct 2010 at 12:37pm
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 12:51pm
Hmm wonder if it the the difference in specific gravity of the mineral oil that cause the heat issues.   BUT it would be a nifty little rig to have just for the geek factor  Hahaha
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 1:22pm
for a basic, all stock PC it works fine, and looks pretty cool. but has no place on a high performance rig.
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 1:44pm
The fans on the rad were all set to low, so this could have been the reason for the temps. It does look nice, but then again it would be a huge hassle changing hardware, esp. the GPUs.
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 1:54pm
not if you dont mind getting a bit messy, then again SLI rigs would be a major pain Smile
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 2:07pm
on high the temps were only 2.5C better, should be 25C lower to be comparable with water.
maxomia View Drop Down
  Quote maxomia Quote  Post ReplyReply bullet Posted: 17 Oct 2010 at 6:42pm
well i would definantly put mineral oil adapting fish in it :D
