Minor complaint about Raven Side Panel CNC...
Post Date: 2010-05-11
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Topic: Minor complaint about Raven Side Panel CNC...
    Posted: 11 May 2010 at 5:18pm
Eh, just to make a note, wouldn't it be possible to fit a second 120mm blow hole onto the side panel of the Raven? (RV01, not RV02). I was a bit disappointed when I only saw one on the side panel, and a few days ago, I got bored and decided to take a quick measurement. On the far end of  the side panel, it seems that two would fit. Been neglecting to say this before too, but the threading on the side panel is little off...makes installing new fans a big pain in the butt.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
  Quote Alex Quote  Post ReplyReply bullet Posted: 11 May 2010 at 8:07pm
Hmmm... perhaps a smaller fan?
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 May 2010 at 8:18pm
just cut your own holes.. put as many as you want. Ouch
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 11 May 2010 at 8:39pm
the hole cutout is in the middle...which i don't understand...completely blocks any sort of refinement lol. only possible way of doing it is getting a whole new side window. well, at least it's only hex screwed on, easy to remove, but as if I have a decent and steady CNC machine to cut it out with...LOL
if cutouts on the side window were put toward the front of the case, then you could probably line up two 120mm fans vertically and get a lot more airflow in there. the airflow from the two 180mms at the bottom doesn't really provide ventilation, it just moves air around.
Edited by ablahblah - 11 May 2010 at 8:47pm
R4D4RPR00F
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
