Mobo selection For DST4Me
Post Date: 2011-11-20
darbebo View Drop Down
  Quote darbebo Quote  Post ReplyReply bullet Topic: Mobo selection For DST4Me
    Posted: 20 Nov 2011 at 4:42am
ASUS P8P67 (Intel P67 Chipset) (New B3 Revision) (Does Not Support SLI)
vs
ASUS P8Z68-V PRO (Intel Z68 Chipset) (Features Intel Quick Sync Technology)
DST4ME, in my build roughly 3 weeks ago you suggested me to use the 1st mobo listed above, and yet now you are recommending the 2nd mobo to some of the guys in the forum.
Our needs/specs are roughly the same, non SLI, want to play diablo 3, skyrim, etc
So my question is, is there some update that caused you to start recommednign the PRO to others?
Thanks!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Nov 2011 at 5:06am
I normally recommend the z68 to people that need sli, or what a higher oc, also now I think the price difference is less.
Are you sure I'm recommending it to non sli members? if I did it was purely for stage 2 oc.
Edited by DST4ME - 20 Nov 2011 at 5:06am
