Monitor connection cables HDMI or DVI
Post Date: 2009-03-06
angler View Drop Down
  Quote angler Quote  Post ReplyReply bullet Topic: Monitor connection cables HDMI or DVI
    Posted: 06 Mar 2009 at 1:00am
I just bought a Dell 2408wfp Monitor and my machine is being built which will have a GTX295 card in it. I currently use a Monster DVI cable to connect my monitor and am planning on using it for this machine also but realized I now have an HDMI option. Is my thinking right that there would be no benefit in using HDMI since I am not pumping sound into my monitor? My thought is that digital is digital and both types of cable would produce the same results. Is ther any benefit to going to HDMI that I am not aware of?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2009 at 1:03am
well hdmi is a bit better but the hdmi output on the 295 does not post, so you will be connecting via dvi anyways.
Edited by DST4ME - 06 Mar 2009 at 1:04am
  Quote angler Quote  Post ReplyReply bullet Posted: 06 Mar 2009 at 1:07am
What do you mean "does not post". Are you saying it is disabled?
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 06 Mar 2009 at 1:23am
I think he's saying that it won't display the BIOS text screens that you normally see during startup.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Mar 2009 at 2:36am
ya you can't see the boot screen or anything from it.
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 06 Mar 2009 at 2:40pm
As far as quality of image, unless you have studio quality display panels costing tens of thousands of dollars you will never be able to see the difference between DVI and HDMI anyway.
The major difference between the two is that HDMI includes audio information in its spec and DVI does not have it.
There are some slight specification tweaks, but like I said, you need an eagle eye and a monitor far better than even a top tier gaming monitor to see the difference.
Here is an article on the subject:
http://forum.ecoustics.com/bbs/messages/34579/122868.html
Dave Ouch
Edited by Kliebor2 - 06 Mar 2009 at 2:42pm
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
  Quote angler Quote  Post ReplyReply bullet Posted: 06 Mar 2009 at 11:09pm
Thanks guys and thanks Dave - great article!
