Monitor connections
Post Date: 2019-02-18
Dgodare View Drop Down
  Quote Dgodare Quote  Post ReplyReply bullet Topic: Monitor connections
    Posted: 18 Feb 2019 at 5:59am
Waiting for my system to arrive and have a question; I have 2 monitors 1. 1440 and 1. 1080 I’m wanting to know what connections to use
I purchased vanquish 7 level 4
God Bless
  Quote Cretae Quote  Post ReplyReply bullet Posted: 19 Feb 2019 at 6:51am
Your video card supports 3 display port 1.4 connections and 1 HDMI 2.0b. Display port is preferred at 1440p especially if you have G-sync. It transmits a higher bandwidth than HDMI, and is capable of higher refresh rates if you monitor supports this. HDMI is the choice for speaker-equipped monitors as it carries audio as well as video. However, a display port cable will carry audio with an HDMI adaptor.
Generally speaking, if your monitors are not ancient specimens, you should be fine using the cabling that came with them.
Hope it helps.
  Quote Dgodare Quote  Post ReplyReply bullet Posted: 20 Feb 2019 at 6:02am
Very helpful...tyvm
God Bless
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Feb 2019 at 7:29am
This page was generated in 5.957031E-02 seconds.
