monitor help
Post Date: 2011-11-28
rX-saint View Drop Down
  Quote rX-saint Quote  Post ReplyReply bullet Topic: monitor help
    Posted: 28 Nov 2011 at 5:57pm
hi all, just got my new pc from ds, i have 1 gtx 580 sc 8 gig ram, asus 967 deluxe, i7 2600k over clocked to 4.5 ghz, a 1050 watt psand txhe had x case.im playing bf3 and black ops and my monitor is got lines going through it when i move side to side or up and down, lines are going vertical across. link to my monitor is http://www.newegg.com/Product/Product.aspx?Item=N82E16824009206.. i really don't like the monitor at all. only gets rid of problem when i turn on vsync. is there a better monitor to get?? was gonna go and get another gtx 500 sc and eli them up..thnx
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 12:27am
re-seat your gpu, reinstall your drivers, make sure all connections are right.
1. response time is a bs number, its there to fool you and does not represent the true response time of the monitor, there is no real way of truly finding what response time is, the closest to it is white to white but you don't see that, you see grey to grey or black to black cause they give small numbers to fool users but they don't mean anything, there are different methods to get these numbers also, and each will give a different number as results, therefore you can even compare one to the other, cause we don't know what method was used for which, and even if we did, still GTG or BTB don't mean anything.
2. contrast ratio is also bs number.
here is a good ips one:
Dell UltraSharp u2312
sc cards are not a great idea, also you should have gone with sli 570 for that res, thats all you needed.
without vsync, your gpu and monitor go out of sync and you get what you are experiencing.
Edited by DST4ME - 29 Nov 2011 at 12:28am
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 2:19pm
ok will try that. I'm gonna give my son my gtx 580 sc and go with 2 gtx 570 in sli. do i need the 2 gig cards??
Dynamus View Drop Down
  Quote Dynamus Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 4:10pm
Nope, the 1.2's are just fine.
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 4:43pm
ok i reseated my video card and reinstalled drivers and still having same problem. fixes it when i turn on vsync. do u think i will have the same problem with 2 gtx 570 and the dell u2312 monitor??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 7:12pm
With vsync off you might, why are you turning it off?
you don't need to get rid of the 580, you can do sli 580, I was just let you know all you needed was sli 570 vs sli 580, so next time you can save some money if you find yourself in the same situation, and wanted the readers to know for your res all they need is sli 570, but if you get sli 570 then thats even more money, at this point just get another 580 if you need it, unless your son is over due for a gpu upgrade.
Edited by DST4ME - 29 Nov 2011 at 7:15pm
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 8:22pm
its already on off, when i put it on it it fixes the problem but caps my fps to 60. is it suppose to be on??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2011 at 11:26pm
Thats my point, on a 60Hz monitor you are not going to notice more fps then 60.
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 30 Nov 2011 at 12:28pm
ok guess i will put vsync on then.. i ordered another gtx 580 sc to sli them, what pci-e port do i put it in on my asus p67 deluxe m.b. ? also do i use the asus bridge on them that came with my motherboard?? thnx for your help DST4ME..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 30 Nov 2011 at 6:46pm
the white pci slot, its gonna be at x8,if you put it on the black one then its gonna be at x4 and you don't want that.
yes use the bridge that came with mobo. Your psu will have the connectors for card also, I think you need a 6pin and a 8 pin, the cables for it is either hidden behind the other side panel or with extra stuff you got.
My pleasure
Edited by DST4ME - 30 Nov 2011 at 6:46pm
