Monitor Help!
Post Date: 2008-06-10
tksuther View Drop Down
  Quote tksuther Quote  Post ReplyReply bullet Topic: Monitor Help!
    Posted: 10 Jun 2008 at 3:13pm
I'm looking for a 22" LCD. I'm going crazy reading reviews. Just when I think I found the right monitor, there's a catch like bleeding or humming noises, etc. Anyone here have a 22" LCD recommendation from their own experience? Two things I know I don't like are glossy trim and a glass screen. My GPU is a single 9800 GTX. I do some gaming but not a lot of super intense stuff - mostly do photo work. Thanks!
david5182 View Drop Down
  Quote david5182 Quote  Post ReplyReply bullet Posted: 10 Jun 2008 at 5:23pm
Get either Dell 2208WFP or the latest 22" Samsung model.
Tripwire View Drop Down
  Quote Tripwire Quote  Post ReplyReply bullet Posted: 10 Jun 2008 at 5:37pm
950Si | 1000W C HX | Q9450 OC | 4GB C DDR2 1066MHz | 150GB WD(10K)+250GB WD(7200) | Air Cool 3 | 2x SLI 8800GTX OC | SB X-Fi FPS
Order-5/18
S1-5/20
2-5/22
3-6/9
4-6/9
5-6/9
6-6/16
7-6/17
Wallyguitar View Drop Down
  Quote Wallyguitar Quote  Post ReplyReply bullet Posted: 10 Jun 2008 at 5:42pm
Nothing is perfect, but some success rates can be better than others.  If you find one that's in your price range that has a pretty decent ratings/reviews (why I'm a newegg fanboi), then go with it.  There's always a chance that something that you purchase is going to be defective.
Personally I'm a fan of Acer, Hanns-G, and Samsung.  Go with the company that you've had a good track record with.
Click pic to see config
  Quote tksuther Quote  Post ReplyReply bullet Posted: 10 Jun 2008 at 9:47pm
What do you guys think of this?
http://us.lge.com/products/model/detail/computer%20products_lcd%20monitors_full%20line%20of%20lcd%20monitors_W2252TQ.jhtml
Dog Lover View Drop Down
  Quote Dog Lover Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 12:30pm
When I got my new rig, I figured it was time to upgrade from my 19 inch CRT.  I got lots of input on the boards here and ended up taking the advice of many who suggested I go with a Samsung SyncMaster 225 BW. (22 inch flat panel).
I run all of my games maxed out and it is the best looking monitor I have ever had or seen.  I am beyond pleased with it.
I did a lot of web searching and got it from one of the vendors on Pricegrabber.com.  It was way cheaper than anywhere else, had a 50 buck mail in rebate, no tax and FREE shipping.  From the day I ordered it until the day it showed up on my door step was three days!
Extreme Case
850 Watt Thermaltake
Qx6850 3.0 Ghz (stock speed)
780i Motherboard
4 G, 1066 RAM
2X SLI GTX 260, 896
Sound Blaster X-Fi XtremeGamer
Thermoelectric Liquid Chilled
Windows 7,64b
Kliebor2 View Drop Down
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 12:43pm
Samsung make a great monitor, and has won many awards, they make some of the fastest (I picked my monitor) because it has a 2ms response time, very unusual for an LCD. It also has great color saturation, no blur, amazing detail and great view angle.
I am extremely pleased with my Samsung monitor (I have the 225GW) only difference from the BW is mine has a glossy screen, looks crispy in the dark but in very bright conditions gets reflections... but I like gaming with no lights on anyway, makes the graphics look all the cooler :) so that does not bother me.
If you game in a brightly lit environment I reccomend the BW model :)
Dave
Dual PNY OC2 GTX 560Ti
8 Gigabytes DDR2/800
  Quote tksuther Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 1:20pm
The 225 BW is no longer available - bummer.................
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 1:30pm
Samsung has a current 22" LCD however that is actually an improvement on the previous design, that is usually the way it works.
  Quote tksuther Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 3:31pm
Do you happen to know the model number?
  Quote Wallyguitar Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 3:49pm
Try the Samsung T220.  It's the only one on newegg that I found that's 22" and 2ms response.
  Quote Kliebor2 Quote  Post ReplyReply bullet Posted: 11 Jun 2008 at 3:57pm
2232 GW/2232 BW are listed as the current iteration of the 22" LCD on Samsung USA web site
This page was generated in 7.910156E-02 seconds.
