@Monitor Pros
Post Date: 2012-11-18
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Topic: @Monitor Pros
    Posted: 18 Nov 2012 at 3:14pm
I noticed Dell launched a new monitor:
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=225-4015#reviews
How does that compare with the U2711? Should I mix and match these for 3 panel gaming? They are a lot cheaper but I don't understand why. BPrat -- I know you're hiding out there. Whats this all about man?
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=19&l=en&sku=224-8284
Regards,
Xii
  Quote Asangard Quote  Post ReplyReply bullet Posted: 18 Nov 2012 at 4:40pm
Hi xii,
Here is a link comparing the 2 side by side from Newegg:
The differences I see are:  U2711 displays more colors. 1.07 billion to 16.7 million, has a faster response time 6ms to 8ms and has more connectors.  The new U2713HM uses less power and is lighter.
I hope this helps
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 18 Nov 2012 at 8:02pm
Hey thanks mate. Really appreciated.
I wonder how that new monitor would work for gaming.
voidofmeaning View Drop Down
  Quote voidofmeaning Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 1:56am
Both of those Dells are 27" and 2560 x 1440. You could also consider the ASUS PB278Q which has identical size & res but 5ms response and a lesser price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236294
The thing is, at this resolution, this panel type (IPS for Dell, PLS for ASUS), and these particular models, you're looking at a frame or so of input lag (a different stat than pixel response time) with all of them. This is either okay or not okay depending on what kinds of games you play and how demanding you are of their snappiness.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 3:08am
Hi xii...   how's the Black Sheep holding up?
About Dell, the new 2713 is by specs a inferior monitor to the 2711 but in practice is just as good plus thinner, lighter and LED lit for energy conservation.
It does have fewer inputs but for most it probably won't matter.   I believe its cheaper because of fewer inputs plus the LED allows fewer heatsinks and other cost cutting measures.
Unless your a professional editor , photographer, etc that needs the richer color gamut I think the 2713 will be the one to get.      It makes stepping up from the 24" to a 27" with higher res a little easier.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 4:12am
Hey, Asangard....
HAPPY BIRTHDAY      old man.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 4:24am
Happy Birthday Asangard
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 6:27am
Haha - Happy Birthday mate.
Yea, I play FPS, RPGs things like that. Ill prob stick with the U27 unless the ASUS will work with a U27 in the middle for Nvidia Surround.
I'm not sure, I think they need to be the same monitor.
@Bprat -- I'm telling you, my PC is the beginning of Skynet man.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 7:50am
Glad to hear.  I really had no doubt.  Drooling
3D Vision I believe has to be all the exact same monitor.  2D displays can be different but the lowest resolution is what they all default to.  Not 100% but sounds right.
  Quote voidofmeaning Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 8:12am
Yeah, I'd stick with more of the model you already have.
http://www.geforce.com/optimize/guides/how-to-correctly-configure-geforce-gtx-680-surround#1
Monitor Prerequisites
In 2D Surround, any combination of monitors that share common timings is perfectly acceptable, though each must have, at minimum, one DVI, HDMI, or DisplayPort connector. Aesthetically, identical monitors are preferable, but not a requirement.
In 3D Vision Surround, each monitor must be an identical make and model, and you must use three matching digital connectors. We will go into detail below, but you may need additional adapters for this.
Edited by voidofmeaning - 19 Nov 2012 at 9:08am
xii View Drop Down
  Quote xii Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 9:32am
Sweet appreciated.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 7:47pm
Thanks all for the Happy Birthday.Awesome  60 and still counting.
MICHAEL2A View Drop Down
  Quote MICHAEL2A Quote  Post ReplyReply bullet Posted: 19 Nov 2012 at 10:24pm
Wow, you are old! Wink
Happy Birthday from another old guy. As my fathers license plate frame says, "Old guys rule". Big%20Smile
NZXT Switch 810
Asus Rampage V ED10
16GB Corsair Platinum 3000mhz
i-7 X5960, 3.0Ghz-3.5Ghz
Intel 750 800GB NVME-SSD
Corsair H115i CPU Cooler
2 Asus Strix 1080 8GB SLI
Corsair AXi 1200 PSU
