Monitor question for ticket 767030
Post Date: 2012-12-25
BShizzleUniBrizzle View Drop Down
  Quote BShizzleUniBrizzle Quote  Post ReplyReply bullet Topic: Monitor question for ticket 767030
    Posted: 25 Dec 2012 at 8:50am
Any one happen to have a recommendation for a monitor with this set up?
Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible)
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps)
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R)
Optical Drive 2: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
Internet Access: Wireless USB 802.11n Up to 300Mbps (Supports 802.11n/g/b)
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 680 2GB (PhysX) (Overclocked EVGA)
Thx for any help. I don't know much about the newer models out there.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 26 Dec 2012 at 9:46pm
I generally recommend the Dell Ultrasharp IPS displays for top viewing quality and very accurate colors.
I use 3 of the new Dell U2412m displays ($319 at newegg.com) with my DS Hailstorm (Sabertooth X79 Mobo/
i7 3930k & SLI 680's)... The larger 27" model is the Dell U2713HM (on sale at $699 on newegg).    Both panels get very positive reviews.   See lots of monitor reviews at www.tftcentral.com    or   www.CNET.com    or www.prad.de/en/index.html     Both are LED backlit IPS monitors for low heat and low power consumption.   The 24" is a 16 x 10 aspect ratio panel with 1920 x 1200 resolution.... the 27" Dell is a 16 x 9 aspect panel with 2560 x 1440 resolution.
  Quote BShizzleUniBrizzle Quote  Post ReplyReply bullet Posted: 27 Dec 2012 at 7:35am
Thanks alot. I've been hearing a lot about the dell ultra sharps. I think I'll check those out. Thanks again.
