Monitor questionPost Date: 2018-09-25 |
| Author | |
Booter
Joined: 25 Sep 2018 Online Status: Offline Posts: 4 |
Topic: Monitor questionPosted: 25 Sep 2018 at 8:40am |
Hello, can someone please answer a question for me? I’m looking at the Vanquish level 3 and I’d like to purchase a monitor with Gsync. What I’ve read says for the Gsync to work the “system must support DisplayPort 1.2 directly from the GPU. The level 3 comes with Nvidia GeForce 1060 6 Gb, will this work with a Gsync monitor?
Thanks for any help! |
Posted: 25 Sep 2018 at 9:10am |
They have DP 1.4 ports, so, yes, it will support G-Sync. ![]() |
Booter
Posted: 25 Sep 2018 at 10:05am |
Ok thanks for the help
NerdyGamer18
Joined: 03 Oct 2018 Online Status: Offline Posts: 5 |
Posted: 06 Oct 2018 at 12:59am |
I can actually vouch as to what he said is correct, because I'm running 2 vanquish level 3 monitors and yes they do support g-sync. It's also a rad monitor by the way.
| Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
