Monitor questions
Post Date: 2010-06-17
CStormO View Drop Down
  Quote CStormO Quote  Post ReplyReply bullet Topic: Monitor questions
    Posted: 17 Jun 2010 at 10:11am
ok so which do you think is would be better? http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6356589&CatId=3774 which is a 26" 1920 x 1200 3ms vizio refurb but idc about that
or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5522916&CatId=2775 which is a 22" 1920 x 1080 2ms asus
now idc about the size because for gaming i think 22 is the best size i dont mind 26" though because i do more then just gaming on the pc but what im wondering about is the 1ms response time... is that actually noticeable? and the 1920 x 1200 is it big difference? or again something i dont even need to worry about? also these are just 2 monitors i seen when i was looking if any1 know any good deals please post links or say the website i want at least 1920 x 1080 tho and 2-3ms 2 if possible also whatever monitor i get i might get 2 now if i do that should i get another 480?
here is the build im looking at btw so you know what system its for
415379
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Extreme Performance) (Model: X25-M MLC Edition)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Hitachi/Seagate (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Optical Drive 1: DVD�R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
Warranty: 4 Year Limited Warranty with Life-Time Customer Support (4 Year Labor & 2 Year Parts)
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 17 Jun 2010 at 6:10pm
id go with the ASUS MS226H hands down
also consider this http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059 in that range
you will likey not notice a 1 ms difference
MICHAEL2A View Drop Down
  Quote MICHAEL2A Quote  Post ReplyReply bullet Posted: 20 Jul 2010 at 3:34pm
NZXT Switch 810
Asus Rampage V ED10
16GB Corsair Platinum 3000mhz
i-7 X5960, 3.0Ghz-3.5Ghz
Intel 750 800GB NVME-SSD
Corsair H115i CPU Cooler
2 Asus Strix 1080 8GB SLI
Corsair AXi 1200 PSU
