Monitor suggestions.
Post Date: 2009-12-03
CygnusX1 View Drop Down
  Quote CygnusX1 Quote  Post ReplyReply bullet Topic: Monitor suggestions.
    Posted: 03 Dec 2009 at 11:12pm
I'm looking into a monitor for my DS rig. Budget is a serious consideration, $600.00 or less is my budget.
Some gaming, but my DS rig will be primarily for Photography processing and video editing.
I am presently interested in the HP LP2475W 24in LCD Monitor 1920X1200
This is an "IPS" variant, "TFT", "16:10" monitor. All three of which is important in my choice of monitor.
Most monitors are consumer grade "TN" monitors that are typically just fine for most gamers and all normal home  / business uses.
It appears that this monitor has or will be going out of production as I don't find it on the HP web site. Might explain why it's on sale.
It appears that the number of available 16:10 ratio monitors are getting less and less in favor of 16:9.
Anyone have any other suggestions for a monitor with the type of requirements that I am looking for that is $600.00 or less?
I would prefer a 16:10 monitor, but will concider 16:9 as long as it is a "IPS" "TFT" monitor. 1920x1200 is also preferred.
Anyone out there that also uses their DS computer for photography or video editing that can make any suggestions?
Thanks.
philiporphillip View Drop Down
  Quote philiporphillip Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 11:29pm
check out Tiger Direct .. big sale on monitors.
Digital Storm
haf 922
i7-920 oc'd @ 3.6 ghz (1.28v)
evga x58 le edition sli
cooler master v8
6 gb ddr3 1600 mhz mushkin
evga nvidia geforce gtx 295 co-op edition
1000w corsair hx
  Quote CygnusX1 Quote  Post ReplyReply bullet Posted: 03 Dec 2009 at 11:39pm
Thanks, I'll take a look!
user6895 View Drop Down
  Quote user6895 Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 2:08pm
Sorry for being late to respond but I just received my new 24 inch monitor and it is great. Go to Dell and search for U2410 Ultrasharp. This is a 24 inch monitor with 1920x1200 max rez. Check out the reviews I think they covered all questions I had. The great things about this monitor are:
1. HDMI and DVI inputs, Playstation and Computer hookup, no swaping cables.
2. 178 degrees viewing angle both horizontal and vertical
3. Price $599.99
4. The monitor can be rotated to portrait or lanscape.
5. Built in USB ports.
6. Built in card reader.
Good Luck
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 5:50pm
3. Price $599.99
Good Luck
You forgot to add:
1. 6 ms response time
2. IPS panel
3. $480 after tax (assuming you know who to call and what to say :) )
  Quote user6895 Quote  Post ReplyReply bullet Posted: 07 Dec 2009 at 10:45pm
Yah and no ghosting and the control buttons are real cool to. I have hooked mine up to my PS3 and Velocity Micro just to test while I wait for my new DS system. The 1080P is awesome. Ran my Velocity Micro on 1920x1200 and max settings with Graw but it got a little jerky, it only has duo core CPU one 9800 nvidia card. All in all I think for the price it's a great buy. I got mine on sale for $499 during the Thankgiving sale.
  Quote CygnusX1 Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 1:14am
Thanks for the info guys!
It appears that the Dell U2410 is using the same LG panel as the HP2475 that I mentioned in my first post. There are a
similar number of people complaining about the issue of some of these panels are coming out of Mexico with a right to
left, cyan/green - magenta/pink color tint issue. It appears to be a very hit or miss deal for both the HP and Dell monitors.
But, the price is better than the HP model and the Dell is currently in production as the HP is still up in the air from what I
have been able to research so far.
Quoting satsunada: " 3. $480 after tax (assuming you know who to call and what to say :) )"
SOOOO...I don't know who to call or what to say at Dell. Any chance you could coach me on this?Ouch
  Quote satsunada Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 4:34pm
This is confirmed to work, it's from another forum:
Keith Wenzel
1-800-901-3355 ext 94-60854
([email protected])
Mention hardforum (that's the other forum), and that you're looking at buying a U2410, and he'll have someone call you back. He is no longer in the right department, but he'll get the right person for you. They'll apply all the discounts they can (no need to haggle or anything). You may have to mention you saw someone got it for $480. Depending on where you are, taxes may kick in.
Hope I don't get in trouble for this post...
  Quote CygnusX1 Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 6:05pm
Thank you very much for the coaching! I seriously doubt that you could get into trouble. If I call him and I am asked, then I will simply tell him I was reading some reviews during my research into this monitor and found his name and number, but for the life of me I can't remember where I found it, as I read so many sites my eyes were bleeding! Evil%20Smile
Keith Wenzel
([email protected])
  Quote satsunada Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 6:11pm
No no.. mention Hardforum.. I was worried about me getting in trouble here. Good luck and tell us how it works out!
  Quote CygnusX1 Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 7:07pm
OK, my bad! I get it. I'm to be sure to mention Hardforum. See, I told you I needed coaching!
Just looked it up. Am I to mention thats the site where I found his info? Don't want to screw up if I call.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 7:08pm
yes you saw the info somewhere on Hardforum, can't quiet find the post now.
  Quote satsunada Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 7:13pm
Ya, just say something like "I read on Hardforum that you can help me buy a U2410 monitor for my computer" .. should pretty much work itself from there by my understanding.  If you're not comfy calling, send an email. Relax Evil%20Smile  you'll be fine.
Gringo View Drop Down
  Quote Gringo Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 7:58pm
Get the HP2475W.. It doesn't get any better.. it's even better than the dells. It costs a bit more, but I guarantee you won't be dissapointed.. it's really awesome for gaming, incredible. I want to buy a second one!
i7920 oc'ed - Radeon 4870x2
  Quote satsunada Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 8:17pm
Actually it does get better, besides.. both use roughly the same panel and the 2475 is more expensive by a hundred bucks or so. Really no comparison on this budget.
And DST4ME, the topic on HF is in Displays, Dell U2410, and the post I copied is on pg. 51 i think of the topic. I'm pretty sure at least.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Dec 2009 at 10:54pm
lol no I was telling him basically what to say
stmbtwilli View Drop Down
  Quote stmbtwilli Quote  Post ReplyReply bullet Posted: 17 Dec 2009 at 11:54pm
I use the HP LP2475 and I love it. FC2 looks and plays spectacularly. It is hard for me to imagine a better display at this price point.
I only hope that we don't lose sight of one thing - that it was all started by a mouse." ~ Walt Disney
