monitor
Post Date: 2012-01-06
rX-saint View Drop Down
  Quote rX-saint Quote  Post ReplyReply bullet Topic: monitor
    Posted: 06 Jan 2012 at 1:13pm
hey all, i want to get a new 24 inch monitor for gaming. want something that i don't have to v sync . the 24 inch monitor i have now tears aliitle and get a crazy blurry line in the middle of the screen.. i have 2 gtx 580 evga over clocked addition graphics cards on my asus p67 deluxe m.b. and my 17 2600k processor over clocked to 4.5 ghz.. don't care how much the monitor will cost just want something that will not tear up my screen while playing with v sync off.. thnx in advance...
HAL View Drop Down
  Quote HAL Quote  Post ReplyReply bullet Posted: 06 Jan 2012 at 4:06pm
For that rig you, depending on the games, you could handle anything from 1200 or 1600 res.
These three are the highest recommended I have came across:
Dell U2410-24"(1920x1200)(16:10)
Dell U2711-27"(2560x1440)(16:9)
Dell U3011-30"(2560x1600)(16:10)
Edited by HAL - 06 Jan 2012 at 4:09pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Jan 2012 at 11:36pm
You have to have vsync on, what is the point of having it off? your monitor itself will cap you to 60fps anyways.
other IPS monitors then what hall suggested:
Dell UltraSharp U2412M
Dell UltraSharp u2312
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 4:32pm
well when I'm gaming it shows over 100 fps on the monitor not 60. i guess i just don't understand. everyone i talk to says there not using vsync.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 6:05pm
If you are tearing use vsync, your monitor is a 60Hz monitor so even tho you get higher then 60fps you will not really notice the difference.
In a effect what you have here is what we call overkill, not only do you not need superclocked 580s to max out your res on the 24", but you don't even need sli 580, now you are left with all this power that is kinda useless do to the monitor's limitation.
you can get 120Hz monitor (3D) but those are loud and some people say they get a headache from it, there are a couple of people here that like it, but at the end of the day, whether your monitor can do it or not, 60fps is more then enough for smooth gaming.
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 8:29pm
ok. so what monitor will be good with my 580's then so it won't be overkill?
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 8:33pm
I'm playing mw3 and battlefield 3
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 8:36pm
Well why not just use vsync and enjoy 1900 x 1200.
next step would be the 30" HAL posted at 2560 x 1600, but thats a $1100 monitor on sale, otherwise expect to spent $1300 on it.
Or as I mentioned you can look into 120Hz monitors, I don't use or recommend those since they are not ips panel, and are loud, once they are IPS and quiet and 240hz then I will get/recommend those.
  Quote rX-saint Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 8:40pm
ok thnx DST4ME .. i will put on sync for now and save up and get a better monitor later
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jan 2012 at 11:51pm
My pleasure and good luck
Down clock those 580s to stock speeds so they last longer, you won't notice the difference.
Edited by DST4ME - 07 Jan 2012 at 11:52pm
