Monitor
Post Date: 2014-10-03
IanB View Drop Down
  Quote IanB Quote  Post ReplyReply bullet Topic: Monitor
    Posted: 03 Oct 2014 at 12:53am
Hi Guys,
Looking for some help re a monitor.
I've just ordered my new Bolt2, can't wait for it to arrive! In the meantime I'm thinking about a new monitor to go with it. I have a monitor which is a Dell2407wfp, I've had it for a little over 5 years and it still works well.
But is it going to make the most of my new Bolt 2?
Would I benefit from replacing it with something newer and if so what should I be looking for?
Many thanks
Ian
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 03 Oct 2014 at 7:16pm
Hello IanB,
What graphics card did you go with? Are you looking solely for a gaming monitor or will you also be doing some color work.
IanB View Drop Down
  Quote IanB Quote  Post ReplyReply bullet Posted: 03 Oct 2014 at 8:09pm
Hello Nav, Thank you for your interest.
I went with the GTX 970.
It will mostly be used for gaming. There will be no 'color' work as such (by that I'm assuming you mean graphics design/video type work).
Regards
Ian
Nav View Drop Down
  Quote Nav Quote  Post ReplyReply bullet Posted: 03 Oct 2014 at 9:17pm
A lot of gamer's like the ASUS VG248QE Black 24" 144Hz monitor. If it fits your budget, I recommend the GSYNC variant for no-tearing gameplay.
