Monitor wall mounts
Post Date: 2019-05-28
adonias888 View Drop Down
  Quote adonias888 Quote  Post ReplyReply bullet Topic: Monitor wall mounts
    Posted: 28 May 2019 at 2:05pm
Hello everybody, so I just bought a MSI optix MPG27CQ monitor and I was wondering if anyone knows there are any wall mounts for this device?
  Quote Snaike Quote  Post ReplyReply bullet Posted: 28 May 2019 at 2:16pm
According to Amazon it has...
Curved Gaming display (1800R) – The best gameplay immersion
144Hz Refresh Rate
1ms response time helps eliminate screen tearing and choppy frame rates
True colors - NTSC 100% & sRGB 115%
Adaptive Sync – prevent screen tearing
Mounting type: VESA Compatibility - Mountable 100 x 100mm
What you're looking for is VESA Compatibility. 100mmx100mm is the mounting bracket that you'll need.
As someone who has mounted 5 TVs and 3 computer monitors on walls and aftermarket stands I can tell you that the process is very very simple.
Just make sure that which you're mounting it to is set for 100mm x 100mm (75x75 is minimum for monitors)
  Quote adonias888 Quote  Post ReplyReply bullet Posted: 28 May 2019 at 2:30pm
Cool thanks this helps a lot thank you.
Would you know the exact one, or one that you would recommend that I would need for this monitor if not thank you any way for this information.
Edited by adonias888 - 28 May 2019 at 2:37pm
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 28 May 2019 at 3:58pm
FYI...Most monitor wall mounts will fit a range of VESA sizes.. Never have needed to wall mount a monitor, but I have used several OmniMount brand wall mounts for TV's of all sizes and have found them to be very high quality and easy to install.   You can enter this search string on Amazon or NewEgg or B&H Photo Video websites and view mounts that would be VESA 100 X 100 compatible.
OmniMount VESA 100 x 100 wall mount
Edited by HockeyBuck - 28 May 2019 at 4:03pm
  Quote Snaike Quote  Post ReplyReply bullet Posted: 29 May 2019 at 6:31am
HockeyBuck has the right of it. Any mount that you're considering has simply to be VESA 100x100 compatible.
Now, to clarify, I haven't mounted any monitors to the walls, but to aftermarket monitor stands. My current stand is an over/under set up for my dual monitors. The TVs, however, are a different story... 5 TVs and 5 different types of mounts; Stationary, flexible, extending, etc. The only thing you're looking for is the compatibility and you can get what you need.
Just make CERTAIN to follow the wall mounting instructions. It has to be secure.
Good luck and have fun!!
