Multi-Monitor Expansion Modules
Post Date: 2008-10-25
Costone View Drop Down
  Quote Costone Quote  Post ReplyReply bullet Topic: Multi-Monitor Expansion Modules
    Posted: 25 Oct 2008 at 10:47pm
Anyone using a multi-monitor setup here?
I'm considering this DVI splitter from Matrox to spread gaming and apps over three monitors. Looks like a pretty solid GXM!
  Quote Costone Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 10:40pm
Same here with the ATI CC....
You know where I'm going with this with FSX.....I intend to send my DVI out into the box (in full SLI) and split the sig onto all three monitors.
But is it any better to bypass the box and plug each monitor DVI cable directly into the three separate cards (assuming SLI will be supported eventually)? is there any processing advantage to doing that as opposed to splitting off of one card in SLI...?
Edited by Costone - 26 Oct 2008 at 10:41pm
  Quote Costone Quote  Post ReplyReply bullet Posted: 26 Oct 2008 at 11:45pm
My only other concern with displaying games in a wide view format (excluding FS) is that, if you can see a much wider field of view in a game that was only intended for a single monitor display...will there be any wierd quirks revealed at the outer graphics that the programmers never intend to be seen...? How would that affect game play and how disorienting would it be to see incomplete or skewed renderings on the outer fringes?
  Quote Costone Quote  Post ReplyReply bullet Posted: 27 Oct 2008 at 9:18am
I checked out Tom's Hardware review. Article is quite a bit old but it answers most of my q's.
Busy now...report back later.
