Multi monitor setup
Post Date: 2011-04-01
mrw075 View Drop Down
  Quote mrw075 Quote  Post ReplyReply bullet Topic: Multi monitor setup
    Posted: 01 Apr 2011 at 9:35pm
Hey guys, can you give some sample builds for a nice multi monitor capable setup that won;t break the bank...most bang for the buck,  thanks!!
  Quote mrw075 Quote  Post ReplyReply bullet Posted: 01 Apr 2011 at 10:16pm
Budget:  $3000 or so, includes monitors.  Starcraft, COD.  Maybe Crysis 2.  Are multiple graphics cards necessary for this??  Extra cooling power I am sure too.  Best resolutions.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 01 Apr 2011 at 11:13pm
IMHO 2 of these:
Dell UltraSharp U2311H 23
and this pc, you add a second 6970 to it yourself later:
Here you go Ticket# 513057 --- $2322 (To see this build click here)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX)
Video Card: 1x ATI Radeon HD 6970 2GB
Boost Processor: Stage 1: Overclock the processor between 4.0GHz to 4.5GHz (Cooling Upgrade Recommended)
  Quote mrw075 Quote  Post ReplyReply bullet Posted: 01 Apr 2011 at 11:28pm
AMD vs. Nvidia pros/cons can u expand on this?
Also, I have owned a Dell 27 wd in the past and two of them failed within one yr, but that was around 2006 so hopefully they have improved since then.  When it did work, it was an incredible monitor.  I am hesitant to buy one again, but maybe they are okay now?
FR3SHM3AT View Drop Down
  Quote FR3SHM3AT Quote  Post ReplyReply bullet Posted: 02 Apr 2011 at 11:23am
Crysis 2 requires less than the first one did. Dumbed it down for consoles. COD doesn't require sli either. As to SC2 not sure but I'm assuming your PC from DSO will kill them all. Mine does
Fr3shm3at
Edited by FR3SHM3AT - 02 Apr 2011 at 11:24am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Apr 2011 at 5:50pm
Originally posted by mrw075
AMD vs. Nvidia pros/cons can u expand on this?  Also, I have owned a Dell 27 wd in the past and two of them failed within one yr, but that was around 2006 so hopefully they have improved since then.  When it did work, it was an incredible monitor.  I am hesitant to buy one again, but maybe they are okay now?
IMHO 3D nvidia is better, multi monitor ati is better, at higher res like 2560 x 1600, right now I like the ati 6970 cf, for its 2GB of vram.
other then that, its pretty much preference IMO.
I have many monitors from Dell, non has failed, but I can understand where you are coming from after your experience. I like to buy the 5 year warranty for my monitors, so if anything goes wrong, warranty will cover it.
as for the ultra sharp IPS panels latest models, few people have them on the forum and so far no complaints.
