My 3rd DS System!
Post Date: 2022-01-14
NVernice795 View Drop Down
  Quote NVernice795 Quote  Post ReplyReply bullet Topic: My 3rd DS System!
    Posted: 14 Jan 2022 at 7:22pm
just ordered my third DS system, this one is special, in which i went full balls to the wall on its config.
Chassis Model: Aventum X
Exterior Finish: Black Metallic Matte Finish
Processor: Intel Core i9-12900K (5.2 GHz Turbo) (24-Thread) (16-Core) 3.2 GHz (Alder Lake)
Motherboard: ASUS ROG Maximus Z690 Extreme (Wi-Fi) (Intel Z690 Chipset) (Up to 3x PCI-E) (DDR5) (NVLink)
System Memory: 64GB DDR5 5200MHz Digital Storm Performance Series
Power Supply: 1500W Silverstone / EVGA / Thermaltake (Modular) (80 Plus Gold)
Optical Drive: - No Thanks
Storage Set 1: 1x SSD M.2 (1TB Samsung 980 PRO) (NVM Express)
Storage Set 2: 2x Storage (2TB Seagate / Toshiba / Hitachi)
Graphics Card(s): 1x GeForce RTX 3090 24GB (VR Ready) (Founders Edition)
Add On Card: - No Thanks
Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (CPU Only)
HydroLux Fluid Color: Clear Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System)
Cable Management: Exotic Cable Management - Black - (Cable Combs with Custom Color Sleeved Extension Cables)
Chassis Fans: Cooler Master MasterFan Halo (RGB Fans) (Remote Control Only) (14 Fans Total)
Software Control: - No Thanks
CPU Boost: Stage 2: Overclock CPU - Up to 5.1GHz on All CPU Cores
Mouse Pad: Digital Storm Premium Mouse Pad (Standard Size) (Stitched Edges)
Branded Gear: - No Thanks
Priority Build: - No Thanks, Ship Within 21-28 Business Days After Order Is Successfully Processed
Warranty: Life-time Expert Care with 4 Year Limited Warranty (4 Year Labor & 2 Year Part Replacement)
this was indeed the most expensive of the systems i ordered and as of right now the longest one taken to build.
i cannot wait to see it!
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 14 Jan 2022 at 8:13pm
I am on my 2nd Digital Storm that I got a few months ago. Since I am 69 I don't know if I will live long enough to need another.
Your system is indeed a computer dream system!
Be sure to post pictures of the unboxing & happy smiles!
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 14 Jan 2022 at 10:03pm
Sounds like a lovely machine that will last you for years and years!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 14 Jan 2022 at 10:42pm
Congratulations. Awesome
I only have one comment regarding your cooling choice. The Hydrolux Pro is a very good open loop cooling system yet you are only including the cpu in it. If you only want the cpu under liquid you'd do way easier on maintenance to go with an AIO otherwise you will increase the level of care quite a bit (and that assuming no leaks) just for looks (and it will look awesome) BUT that is a strong consideration for some.
Just my 2 cents.
Smile
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 16 Jan 2022 at 10:05pm
I had the same thought as hoserator... Aventum is the best liquid cooled rig in the biz, and the capacity of 3 huge reservoirs is kinda wasted if you are not also using it to cool that big GPU. Think they require you to get the more expensive Performance Edition model. If by chance you don't need a RTX3090 for your specific uses, keep in mind you could drop to the RTX 3080 Ti for near 3090 performance and actually save a couple bucks...as the Ti should actually be the better choice for just gaming use.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 17 Jan 2022 at 12:00am
What HockeyBuck said. The RTX 3090 is not really a gaming card.
