my build any help?
Post Date: 2008-03-06
skywalker View Drop Down
Guest
Guest
  Quote skywalker Quote  Post ReplyReply bullet Topic: my build any help?
    Posted: 06 Mar 2008 at 7:06pm
this is my build .any suggestions? trying to keep the price 4500. or less
i have a DS system built 4 yrs ago and it rocks ! now it is time to upgrade
looked at building myself but love DS tech support
Case: Digital Storm 950Si (Black Anodized Aluminum Finish)
Power Supply: 850W SilverStone Decathlon (Dual SLI Compatible) (Model: DA850) (Silent)
Processor: Intel Core 2 Quad QX9650 Extreme 3.00GHz (1333MHz FSB) (12MB Cache)
Motherboard: nVidia 780i Core 2 Quad (By: eVGA) (nForce 780i SLI)
Memory: 2GB DDR2 Corsair at 1066MHz Dominator (Dual Channel) (Extreme-Performance)
Floppy / Card: - No Thanks
Hard Drive 1: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Hard Drive 2: 320GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: 2x SLI Dual (nVidia GeForce 8800GTX 768MB (By: eVGA) (PCI-Express)
TV Tuner: - No Thanks
Sound Card: Creative Sound Blaster X-Fi XtremeGamer (Recommended)
Physics Card: - No Thanks
Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Zalman Case Fans)
Round Cables: Enhanced Interior Air Flow (Optical Drive & Floppy Cables (Red Cables)
Overclock Processor: - No Thanks, Please do not overclock my processor
Protection: - No Thanks
Pre-Install Game: - No Thanks
LCD Display: Acer 19 inch (Widescreen) (Black Edition) (High-Value Display)
Warranty: 4 Year Platinum Care Extended Parts & Labor Warranty (Highly Recommended)
Digital Storm uses genuine Microsoft® Windows®
Copyright © Digital
  Quote skywalker Quote  Post ReplyReply bullet Posted: 06 Mar 2008 at 7:12pm
also can anyone tell me about stage 3 cooling ? does it take up a bay to
give temp reading and fan control? the one i have now does and it is great to adjust fan rpm when needed. also id dual graphics cards really
needed? or just 1 high end card if so which one is the best?
Edited by skywalker - 06 Mar 2008 at 7:14pm
sundowner View Drop Down
  Quote sundowner Quote  Post ReplyReply bullet Posted: 06 Mar 2008 at 8:43pm
For a 19in monitor SLI GTX's isn't really necessary, I'd go with the 3870X2 or wait until Nvidia releases the 9800x2 which should be within the next week or two.
Pro case with extra fan
Quad Q6600 2.4 OC'd 3.1!
Nvidia 8800GT
Asus Maximus Formula Mobo
2xgb 800mhz corsair
xfire - xuntiltheendx
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 06 Mar 2008 at 8:46pm
From what i take, stage 3 cooling includes the stage 2 heatsink, and it gives you upgraded case fans all around, they also stuff as many fans as they can into the case.
SLI really comes into its own on high resolutions, if you dont play on anything 16--x12-- or above, its usually better to go with a single higher end card. At least thats what ive been told.
V64 + only 2 GB ram is gonna suck your ram away pretty nicely. Id recommend at least 4GB if you wanna go V64. Otherwise just downgrade to V32 or XP.
I personally dont like the extreme chips. I find a OCed 8400 to be enough for gaming at least. While definally higher powered the extreme chip offers less bang for the buck. That 900 bucks saved could be dumped into better hardware, hell you could go triple GTXs for less then that chip, though if youd go that way, youd almost certainly have to get watercooling. The heat would be pretty badass.
Why the 2 seperate Hard drives without any sort of raid? Itd be cheaper just to get one large one if they arnt gonna be in any sort of raid, though im sure there is a reason for it.
Edited by SunfighterLC - 06 Mar 2008 at 8:49pm
