My Configuration ...HELP...
Post Date: 2008-09-29
pgarthw8 View Drop Down
  Quote pgarthw8 Quote  Post ReplyReply bullet Topic: My Configuration ...HELP...
    Posted: 29 Sep 2008 at 11:44am
I'm looking at this setup right now:
Ticket Number: 188331
Total Price with Instant Savings: $2,299.00
Direct Load URL: http://www.digitalstormonline.com/comploadsaved.asp?id=188331
How much of a difference would the 790i MB be over the 750?  Is there going to be a huge differnce between these two motherboards?  Also, I'm looking at two 500gb hard drives.  I want to use one of the drives as normal, the other more for storage for MP3's and files.  I'm not sure what all the raid setups or stripes mean?
Thanks, any help would be appreciated.
gdhart View Drop Down
  Quote gdhart Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 1:40pm
On the HDs and RAID.  RAID-0 is where the two drives will each have half the data written to each drive.  You would end up with one logical drive of 1 TB.  Write speeds are faster because it is writting 1/2 the files to each drive.  The draw back to this form of RAID is that if one drive fails you loose everything on both drives.
RAID-1 is where the two drives are mirrored, i.e. a copy of each file is placed on both drives, so you end up with one logical drive of 500 GB, write speeds are the same as writting to a single drive.  The advantage to this is that if one drive fails you still have all of your files on the other drive, you loose nothing.
If you have the need for RAID-1 it may be best to have one smaller drive for your OS and program installs and then the two 500 GB drives in a RAID-1 for your important pictures/videos/documents that you do not want to loose.
You will see from my configuration that I have 3 500GB drives, One for the OS/Program files and two in a RAID-1 for my important files.  (I also have a couple of external drived for doing a weekly backup.  (I originally had two 500 GB drives in a RAID-0 and one failed - I was fortunate in that a restoration company was able to get my videos, pictures, and emails off of the failed drives.)  For the cost of an extra drive (~$100) I could have saved myself a lot of aggrivation and money.
On the motherboards:
750i supports up to 1333 FSB, 8 USB ports, 4 x SATA, 4 x PATA drives, and Dual SLI.  http://www.nvidia.com/object/nforce_750i_sli.html
780i supports up to 1333 FSB,  10 USB ports 6 x SATA, 2 x PATA, and Tri-SLI.  http://www.nvidia.com/object/nforce_780i_sli.html
790i supports up to 1600 FSB, DDR3 RAM, 10 USB ports, 6 x SATA, 2 x PATA, and Quad SLI with 2 Dual-SLI Cards.  http://www.nvidia.com/object/nforce_790i_sli.html
Edited by gdhart - 29 Sep 2008 at 1:41pm
850W PSU/Pro Case
Q6600-G0 2.7GHz
nVidia 680i A1 Revision
4GB 800MHz XMS2
1x500 GB WD, 2x500GB WD RAID-1
2x500GB Ext
nVidia GeForce 8800GTX 768MB
ATI TV Wonder 650
Air Cooled Stage 3
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Sep 2008 at 4:17pm
If you are not over clocking, go with the 750i.
raid is a waste of time and headache the Raptor is a faster drive, use it for OS and apps, and games. use the second drive for media/personal files
here is a better setup for you:
here you go Ticket# 188538 --- Price: $2134 (To see this build click here)
Power Supply: 650W Corsair HX (Dual SLI Compatible)
Processor: Intel Core 2 Quad Q9300 2.5GHz (1333MHz FSB) (6MB Cache)
Motherboard: NVIDIA 750i SLI Core 2 Quad (Chipset: nForce 750i SLI)
System Memory: 4GB DDR2 800MHz OCZ
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: NVIDIA GeForce GTX 260 896MB (Includes PhysX Technology)
TV Tuner: - No Thanks
Internal Lighting: Blizzard Internal Lighting (Red Edition) (Cold Cathode Tubes)
Modifications: LCD Temperature Display & Fan Controller
Protection: - No Thanks
LCD Display: - No Thanks
also recommend you raise your warranty to 5 years.
Edited by DST4ME - 29 Sep 2008 at 4:19pm
