My Extreme Dream machinePost Date: 2010-08-30 |
Author | ||
nauticus66
Newbie Joined: 28 Aug 2010 Online Status: Offline Posts: 34 |
Topic: My Extreme Dream machine Posted: 30 Aug 2010 at 11:45am |
That's a lot of money so I want to get it right. Please help identify anything I should change or correct...
Total Price with Instant Savings: $3,781.00 Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master HAF 932 (Black Edition: Internal Black Paint Job) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 930 2.8GHz (Quad Core) Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (500GB Western Digital (16MB Cache) (7200 RPM) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional (PCI-Express Slot Based) Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards H20 Tube Color:White Tubing with High-Performance Fluid (UV Lighting Reactive) Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) |
nauticus66
Quote Reply Posted: 30 Aug 2010 at 11:49am | |
I don't know if I should stick with 1 480 and a 750w PS and loose the liquid cooling in exchange for Noctua Dual 120mm Fans High Performance Cooler or go ahead and save some money and splurge on the extreme... how much more performance will it give me?
Beezie
Newbie Joined: 11 Aug 2010 Online Status: Offline Posts: 47 |
Quote Reply Posted: 30 Aug 2010 at 11:56am | |
Noctua dual 120 can cool your computer just fine with those spec`s if you dont really want LC cooling you can save some there
Edited by Beezie - 30 Aug 2010 at 12:24pm |
!ender_
DS Veteran Joined: 24 Oct 2007 Online Status: Offline Posts: 4219 |
Quote Reply Posted: 30 Aug 2010 at 12:13pm | |
definitely not worth it to change anything for the 6 core chip.. it wont help your gaming in the least. if you dropped the 2nd video card and went to an extreme chip you would only decrease your gaming power.
im sure you know that you dont need liquid cooling, but obviously that is preference
the build looks good to me if thats what youre looking to spend, there are no silly mistakes or anything if thats what you were asking
Dragoonseal
DS Veteran Joined: 03 Apr 2009 Online Status: Offline Posts: 2247 |
Quote Reply Posted: 30 Aug 2010 at 12:16pm | |
The Noctua NH-D14 fits on the EVGA x58 LE just fine. The one it does not fit on is the earlier and more expensive EVGA x58 3X SLI. |
Lilim
!ender_
both the nocua u12p and 14 fit the evga LE
Beezie
Quote Reply Posted: 30 Aug 2010 at 12:22pm | |
ah ok that explains it Edited by Beezie - 30 Aug 2010 at 12:24pm |
!ender_
Quote Reply Posted: 30 Aug 2010 at 12:36pm | |
both the nocua u12p and noctua 14 fit the evga LE
nauticus66
Quote Reply Posted: 30 Aug 2010 at 1:36pm | |
Ender, in your write up you suggested that if someone were to get dual 480'S to water cool them before you liquid cool the CPU, Are you saying even with dual cards I don't need liquid cooling? Cuz I'd be saving almost 500 bucks. Liquid cooling looks cool but if I can save 500 good bye LC lol.
In the configuration choices they provide, the only one with cooling for both cards and the CPU was the stage 6. Ender I'm kinda plagiarizing your 2k plus build here so my question to you is how much of a difference will I see in my gaming (Age of Conan boss fights are hard on systems) between your 1 480 card build and a 2 480 card build? is it the difference between seeing 100+ fps and 50 fps or more like a machine barely ticking over versus a machine getting pushed. Or does it just boil down to bragging rights? |
nauticus66
Quote Reply Posted: 30 Aug 2010 at 1:56pm | |
OK let me do this the right way...
1) Monitor size: 22" Acer
2) Budget: 3k tops
3) whether you will use any equipment from your last computer on
the new computer: I only need the tower.
4) General uses to be done on the computer: Gaming 90% internet, music etc. 10%) I can be on line gaming for 5+ hrs. |
!ender_
Quote Reply Posted: 30 Aug 2010 at 1:57pm | |
theres no setup that needs water cooling, its not technically a luxury becuase it can help you improve performance with higher overclocks, but its never a requirement, if you want to overclock the crap out of the cards, LC will keep it cool and quiet, but other than that, the gains are not very cost effective
Yes and No - the gains from SLI are very substantial, nothing to be argued with, but it depends on what game youre talking about... for example, mw2 caps fps at 90, period.. so an sli setup on that game would show no difference (maybe a difference at a high resolution becuase it should have a higher minimum fps than just one card)
but on a newer or tougher game like metro2033, the gains will be obvious. the increase wouldnt be double (like 50 vs 100 fps), closer to 60-80% gains, depending on the game
!ender_
Quote Reply Posted: 30 Aug 2010 at 1:58pm | |
no need to start over, you were mostly right, maybe just overzealous on the cooling. liquid is nice to keep overclocked GPUs cool and quiet, but if youre building a gaming only system, you dont need to overclock dual 480s
nauticus66
Quote Reply Posted: 31 Aug 2010 at 6:23am | |
al3xLJ
Groupie Joined: 29 Aug 2010 Online Status: Offline Posts: 217 |
Quote Reply Posted: 31 Aug 2010 at 7:00am | |
That's very similar to what I'll be getting :)
But...green? :P
!ender_
Quote Reply Posted: 31 Aug 2010 at 9:21am | |
nauticus did you read the posting guide linked in my signature?
definitely avoid the fan upgrade, the haf cases already have good cooling
and probably best to avoid the os tweak, win 7 is already optimized pretty freaking well, most of the other stuff they could change would be preference and could limit some of your uses depending on what you do
plus i bet they leave the backup and indexing which are the main resource drains of 7 that i remove first
nauticus66
Quote Reply Posted: 31 Aug 2010 at 10:18am | |
Ya I read your guide which is what I was basing things on, I was debating on the fan upgrade but thought the green fans would look cool... lol its an easy scratch off. The tweeks I was wondering at cuz I usually don't worry about that too much but DS was offering it free so... maybe they know something I don't...
nauticus66
Quote Reply Posted: 31 Aug 2010 at 10:19am | |
so how would this machine fair in BFBC2 or COD4? or crysis?
!ender_
Quote Reply Posted: 31 Aug 2010 at 10:23am | |
its true you could gain from what they change, and if you dont do much but game its probably ok
the green led fans would look cool but they are all 120mms which means a significant noise increase over the stock fans, so thats your choice
nauticus66
Quote Reply Posted: 01 Sep 2010 at 10:18am | |
EVGA X58 LE Edition SLI (Intel X58 Chipset) is no longer in DS mobo list when you go to customize a configuration.
!ender_
Quote Reply Posted: 01 Sep 2010 at 10:34am | |
thats correct EVGA has discontinued this and is now selling the similarly priced evga SLI 3, which is an improved revision
nauticus66
Quote Reply Posted: 01 Sep 2010 at 10:50am | |
So does that mean the Noctura dh14 is no longer a viable option on my build given that the description says it won't fit the regular EVGA X58 3X SLI
!ender_
Quote Reply Posted: 01 Sep 2010 at 11:24am | |
i dont see either board mentioned on this list
so we will have to hear from DSO on that one
